I am aware that every sensor has a certain inaccuracy. The selected sensors correspond to the specifications for the project. At the end, I will perform tests and measure the pressures at the different locations. If it then turns out that the pressure difference should be too small and the sensors do not detect them, this is a reasonable result.
Now I will first try to use more than one sensor with the multiplexer. But I don't know very much about the programming. I got the Code that I posted from this forum and I kinda understand it, but I would'nt be able to write something like it on my own.
So I ask if anyone knows how to do basic programming with a multiplexer. So do you have to address the individual channels of the multiplexer individually and then use the "normal" code of the respective sensor, or does it work completely different?
