Hey everyone, I am designing a pressure regulation system for tank and will be using a proportional valve, a MOSFET, a power supply and an air supply to the valve along with an Arduino UNO R4 to control everything. Also a diffrential pressure sensor.
My goal is to have slight overpressure in the tank, around 1000 Pa.
For this I need a pressure regulator that works in the magnitude of Pascals and not kPa or MPa.
I have gone through most of the posts here regarding this topic and have looked at valves from SMC, Clippard etc.
Do you have any suggestions for my use case? I am also currently having a look at alves from Festo
How big is the vessel you want to fill ? What is it ?
What is the source of air , pressure flow ?
Do you want a pressure regulator or control of a valve ? What valve have you got ?
