i have a mpx2200a pressure sensor and would like to use it as a simple barometer. the pin out of the sensor is:
pin 1: gnd
pin 2: vout+
pin 3: vin
pin 4: vout-
can i use analogread for obtaining the voltage value returned at pin2 by connecting pin2 to analog pin0 and pin4 to gnd on the arduino. i have done this but don't seem to get the correct value.
well, i am pretty new at this and was going to use the sensor as a very simple barometer.
i would like to read the voltage coming from pin2 and use an equation to come up with the current barometric pressure. i guess i would need some sort of an op-amp to amplify the voltage huh?
what would i do with the vout- pin though, tie it to ground?
The Instrumentation amplifier's job is to take the 40 milli volt span between high and low pressure and make it meaningful. 0-40 milli volts is not a voltage that the arduino analog pin can make a lot of use out of.
