hello i am using a regular pressure force sensor to get the trigger for play a drum sample in max msp .
i am sure that there is many ways to improve the system
but still its hard for me to find a way to play on it in rhythm
its look like it hard for the sensing area to read the signals fast
maybe there is a programing solution in max
to consider that every hit on the same sensor getting inside to a different groves object (it helpt me make that every hit is not dependent in the previous hit's volume)
or a beter sensor for using
because rhythm it really hard to get!! :-?
thanks everybody !
i am adding a bit
i dont want to use piezo for getting more sensitive signals
but i would like to use thing to hit the sensor with small surface and most of the sensors are not reading it
hi grumpy mike thanks a lot for ...
during that i am writing to you i understand some few things
it a bit of programing in max that i need to work on
but still i would like to know aboute sensors that sending value when i am hit them with smaller surface for example if i hit it with a chopstick
if there is an alternative force flexi sensors for that ?
