500 rupees is 7.5 dollars.
200 mbar is 20 kPa or 200 hPa.
A gauge pressure sensor measures the pressure relative tot the normal air.
Do you want to submerge the sensor, or are you using a tube and measure the pressure at the top of the tube ?
Instead of a gauge pressure sensor, perhaps you could try two BMP085 or BMP180 chips. One in the tank/tube and one outside the tank for the air pressure. Calculate the difference.
On Ebay are many MPS20N0040D for less than 2 dollars. But you need to amplify the output.
Perhaps you can use the outputs for a very rough indication of the pressure, or you might use the internal analog amplifier of the Arduino Leonardo and Arduino Mega 2560 (the Arduino Uno doesn't have the internal analog amplifier).
The internal analog amplifier is not used a lot, you probably need some help to program the registers, and I have not used that yet.
On Ebay are also many pressure sensors for cars, for under 10 dollars.
Koepel:
...or you might use the internal analog amplifier of the Arduino Leonardo and Arduino Mega 2560 (the Arduino Uno doesn't have the internal analog amplifier).
I have a Mega, and would like to know how to use the "internal analogue amplifier".
Which page of the datasheet.
Leo..
Open the "Complete" datasheet from here : http://www.atmel.com/devices/atmega2560.aspx
Go to page 283.
It is a lot like a instrumentation amplifier, two high impedance inputs, positive and negative and a programmable gain can be set to 1x, 10x or 200x. The internal reference of 1.1V can not be used in differential mode. The resolution will be less than 10 bits. The voltage should be calculated with a factor of 5.0 / 512.0 instead of 5.0 / 1024.0.
It is a nice feature, I wonder why it is not used more often.
This makes it hard to understand : "The 16 channels are split in two sections of 8 channels where in each section seven differential analog input channels share a common negative terminal (ADC1/ADC9), while any other ADC input in that section can be selected as the positive input terminal. If 1x or 10x gain is used, 8 bit resolution can be expected. If 200x gain is used, 7 bit resolution can be expected.
AWOL, please explain.
The cheapest pressure sensors contain only a wheatstone bridge, and some ATmega chips have an internal differential gain (so an external OpAmp is no longer needed), and many new Arduino users think that the I2C can be used with long cables. So far nothing out of the ordinary.
Koepel:
It is a problem of noise floor. At 10X don't expect to read better than 1:256.
For 200X don't expect to read better than 1:128.
Note also that resolution is not the same as accuracy.
Dwight
It would be good enough if a cheap solution is required. The numbers in the datasheet are without averaging. Small changes can still be detected I think with software averaging.
I see many of these on Ebay and dx.com and Banggood and other websites : http://www.ebay.com/itm/131546887010
This is a tutorial for them : http://langster1980.blogspot.nl/2014/11/how-to-use-pressure-sensor-with.html
In that tutorial a OpAmp is used, but a instrumentation amplifier should be used instead. A OpAmp disturbs the wheatstone bridge of the sensor.
I think that using the internal differential gain would result into about the same accuracy as that circuit.
