Pretending multiple values
Hey guys i gave little problem. I work on Rfid reader system. Everytime i attach card to reader serial monitor start writing values as long as I remove the card. How do i prevent that?
#include <SoftwareSerial.h>
const int BUFFER_SIZE = 14; // RFID DATA FRAME FORMAT: 1byte head (value: 2), 10byte
const int DATA_SIZE = 10; // 10byte data (2byte version + 8byte tag)
const int DATA_VERSION_SIZE = 2; // 2byte version (actual meaning of these two bytes
const int DATA_TAG_SIZE = 8; // 8byte tag
const int CHECKSUM_SIZE = 2; // 2byte checksum
uint8_t buffer[BUFFER_SIZE]; // used to store an incoming data frame
int buffer_index = 0;
SoftwareSerial ssrfid = SoftwareSerial(2,8);
ssrfid.begin(9600);
ssrfid.listen();
Serial.println("INIT DONE");
if (ssrfid.available() > 0){
bool call_extract_tag = false;
int ssvalue = ssrfid.read(); // read
if (ssvalue == -1) { // no data was read
return;
if (ssvalue == 2) { // RDM630/RDM6300 found a tag => tag incoming
buffer_index = 0;
} else if (ssvalue == 3) { // tag has been fully transmitted
call_extract_tag = true; // extract tag at the end of the function call
if (buffer_index >= BUFFER_SIZE) { // checking for a buffer overflow (It's very
Serial.println("Error: Buffer overflow detected!");
return;
buffer[buffer_index++] = ssvalue; // everything is alright => copy current value to buffer
if (call_extract_tag == true) {
if (buffer_index == BUFFER_SIZE) {
unsigned tag = extract_tag();
else { // something is wrong... start again looking for preamble (value: 2)
buffer_index = 0;
return;
unsigned extract_tag() {
uint8_t msg_head = buffer[0];
uint8_t *msg_data = buffer + 1;
uint8_t *msg_data_version = msg_data;
uint8_t *msg_data_tag = msg_data + 2;
uint8_t *msg_checksum = buffer + 11; // 2 byte
uint8_t msg_tail = buffer[13];
long tag = hexstr_to_value(msg_data_tag, DATA_TAG_SIZE);
 Serial.println(tag);
return tag;
long hexstr_to_value(char str, unsigned int length) { // converts a hexadecimal value
char
copy = malloc((sizeof(char) * length) + 1);
memcpy(copy, str, sizeof(char) * length);
copy[length] = '\0';
// the variable "copy" is a copy of the parameter "str". "copy" has an additional
long value = strtol(copy, NULL, 16); // strtol converts a null-terminated string to
free(copy); // clean up
return value;
What do you mean? If English is not your first language try using...
"prevent that"...
I want to prevent multiple values print , if there is same card it will print olny once.
ouuu sorry prevent
Pcode
if last code != this code
  print the code
  last code = this code
I tried that but it doesn't write anything
What "that" did you try? We need to see actual code.
I can't read your code, the formatting makes my head spin. Please fix it. The forum guidelines have links to instructions for using code tags. Auto format your code using ctrl-T in the IDE before you upload.
ssrfid.begin(9600);
ssrfid.listen();
return;
buffer_index = 0;
return;
buffer_index = 0;
return;
long old;
if(old!= tag){
old = tag;
return tag;
char
return value;
Auto format your code. Then upload it with code tags!
in these line
long old;
if(old!= tag){
old = tag;
return tag;
SoftwareSerial ssrfid = SoftwareSerial(2, 8);
  ssrfid.begin(9600);
  ssrfid.listen();
  if (ssrfid.available() > 0) {
      return;
      buffer_index = 0;
      return;
      } else {  // something is wrong... start again looking for preamble (value: 2)
        buffer_index = 0;
        return;
  long old;
  if (old != tag) {
    old = tag;
  return tag;
long hexstr_to_value(char *str, unsigned int length) {  // converts a hexadecimal value
  char *copy = malloc((sizeof(char) * length) + 1);
  return value;
variable 'old' is dynamically allocated because it's in a function. It's not remembered between calls. You need to declare it with the 'static' keyword.
Thank you, it works perfectly
See also: R503 and RDM6300 readers
