Hey...so I seem to have made a terrible mistake with my Mega 2560. I had it connected to a 12v 1amp wall wart with the following:
- Ethernet Shield
- DHT11 Humidity/Temp sensor
- SparkFun Logic Level Converter - Bi-Directional
- TSL2561 Lux sensor
- 2 PowerSwitch Tail IIs
They worked as expected for a few seconds (about 10?) but then most notably the lights connected to the powerswitch tails would turn off. A little perplexed, though suspecting a power problem (as I'd had everything set up with a 5v 2amp wall wart and things were fine) I connected my multimeter to the 5v power pin, unplugged and reconnected the wall wart. Things came on for less than a second and then went out...and then I noticed a nasty smell. I grabbed the board and it was warm (but not super hot) near the voltage regulator and now the barrel jack will not power the board (but the USB will!).
I am trying to figure out 2 things:
- Considering the AMS1117 voltage regulator is rated up to 1amp, I figured I wouldn't really have to worry about frying the regulator with 12v 1amp no matter the load (as the wall wart would at worst not be able to supply enough power). Seems that's not the case?
- Is there a way to test out the regulator while still on the board?
I apologize if this all seems pretty stupid, but any advice would be greatly appreciated!
