PrettyOTA: Over the air (OTA) update library for ESP32 series chips
Hi! I want to share a library for ESP32 series chips I have been working on in the past time.
A simple to use, modern looking web interface to install firmware updates OTA (over the air) inside your browser or directly from PlatformIO/ArduinoIDE.
PrettyOTA is available in the ArduinoIDE Library Manager and PlatformIO. Just search for "PrettyOTA"
PrettyOTA provides additional features like one-click firmware rollback, remote reboot, authentication with server generated keys and shows you general information about the connected board and installed firmware.
Additionally to the web interface, it also supports uploading wirelessly directly in PlatformIO or ArduinoIDE. This works the same way as using ArduinoOTA.
The documentation can be found at GitHub (see below for the link).
Demo GIF: Link to gif at ImgBB
Github (with documentation): PrettyOTA on GitHub
ArduinoIDE: Just search for PrettyOTA inside the ArduinoIDE Library Manager and install it. A minimal example is included.
PlatformIO: Just search for PrettyOTA inside PlatformIO Library Manager
PrettyOTA on PlatformIO
Why?
The standard OTA samples look very old and don't offer much functionality. There are libraries with better functionality, but they are not free and lock down a lot of functionality behind a paywall. So I wanted to make a free, simple to use and modern OTA web interface with no annoying paywall and more features.
Currently only ESP32 series chips are supported.
Features:
  • Drag and drop firmware or filesystem .bin file to start updating
  • Rollback to previous firmware with one button click
  • Show info about board (Firmware version, build time)
  • Automatic reboot after update/rollback
  • If needed enable authentication (username and password login) using server generated keys
  • Asynchronous web server and backend. You don't need to worry about changing the structure of your program
  • Customizable URLs
  • mDNS support
  • Logged in clients are remembered and stay logged in even after update or reboot
  • Small size, about 25kb flash required
Issues?
If you experience any issues or have question on how to use it, please open an issue at GitHub or start a discussion there. You can also post here on reddit.
Have fun using it in your projects! :slight_smile:
