Prevent external input voltages "back-powering" circuit through Arduino when powered-down
Hi guys,
Just wondering what you think is the best way to prevent an external +5V signal (connected to an Arduino input pin) powering my circuit when my Arduino is powered down? I guess I could use an NPN transistor, with the Arduino pin connected to C (with internall pull-up active), Ground connected to E, and the +5V signal connected to B through a 100k resistor or something. Could I also just use a basic hex buffer (I have 3 of these +5V signals connected to separate inputs, so this would mean fewer components)? I'm not sure what happens to the output of a buffer when the IC's +5V line is "off" but the inputs are at +5V... Will the outputs stay in High-Z during power-down regardless of the states of the inputs?
Thanks for any help.
EDIT - just in case I wasn't clear, I mean I want to prevent an input powering the Arduino through the diodes present on the IO pins.
Try to connect in series between the pins a high resistance resistor, I guess 100k or bigger. However, it depends on what this connection is used for. It's generally not a good idea to have a piece of electronics that has power and is connected to other components that don't have power.
Your buffers will work but the results will be interesting. You will forward bias the input protection diodes, that will in turn power the outputs at a lower voltage, that in turn will forward the protection diodes in the Arduino. You could use a tristate buffer that will enable when the Arduino is powered.
