Previously working stepper motor project won't work and behaves erratically after getting back into it
Hello, everyone!
I've been lurking on the forums for a while, but now I’ve run into a problem with a project of mine, and I’m out of ideas.
So, back in December, I was working as practice on a little stepper motor setup with a relay and two motors: one rotating continuously at a set speed, and the other rotating intermittently.
The basic setup is:
  • Arduino Nano clone
  • Start/Stop button for the whole system
  • NEMA 23 Motor on TB6600 rotates continuously
  • NEMA 17 Motor on A4988 rotates intermittently
  • Relay switches in sync with the intermittent movement of the NEMA 17 Motor
At that time, I wrote the code and set everything up on the breadboard as usual. It worked flawlessly. I made some timing adjustments, it worked again, etc.
Anyway, now, a month later, after leaving the electronics assembled on a shelf, I got back to it, wanting to solder everything onto a perfboard. For some mysterious reason, something went south.
First off, the smaller NEMA 17 motor, driven by the A4988 driver, just vibrated the shaft when starting, instead of making the correct movement (it did vibrate intermittently, as the sketch dictated though). At this point, both the NEMA 23 motor and the relay worked fine.
I went through a diagnostic process, checked everything I could, added a decoupling capacitor (which I had forgotten on the A4988 12V input), and switched the power supplies I was using (random ones I had lying around the house) for a new 12V 10A switching power supply more appropriate for the job.
During all this, things only got worse. First, the NEMA 23 motor stopped working, and now even the relay stopped. At times, they’d come back, etc. The system is now completely unreliable.
About the TB6600 driver, one mistake I did was accidentaly plugging one of the signal grounding wires into the +12v rail on the protoboard once, but then the issue persisted after using another TB6600 correctly wired.
Below is a list of all the things I did for testing and diagnosing:
Note: The motors are not connected to any mechanical load, so this isn't a torque issue.
  • I checked with another NEMA 17 motor I had, and the issue persisted.
  • I tested both of my NEMA 17 motors and my NEMA 23 motor on another controller device I have here, and all of them worked correctly, meaning the problem isn’t with the motors.
  • I checked the continuity of all connections with a multimeter.
  • I also checked several times the order of the connections for the NEMA 17 and 23 motor cables, in case I made a mistake.
  • I disassembled the entire prototype and remade all the connections on another breadboard, but the issue persisted.
  • I checked the voltage adjustment on the potentiometer of the A4988 driver, adjusting it according to the correct load for the motor, and considering the sense resistor value.
  • I reinstalled the script on the Arduino several times, even trying different versions.
  • I bought another A4988 driver; the issue persisted, and then worse than just vibrations on the NEMA 17, I got nothing on it. Switching back to the previous A4988 unit got the vibrations back, so maybe the second unit got fried.
  • I tested with another TB6600 driver I had lying around. Same issue.
Below, I’m sending pictures of the setup, a diagram of the connections, and the full sketch code(I translated what I could from the original where portuguese was used here and there):
// Movement Setup
const int DEGREES = 180;                       // Motor 2 angle
const unsigned long TIME = 2000;       // Motor 2 pause time
const int V1 = 1000;                               // Motor 1 Speed
const int V2 = 500;                                // Motor 2 Speed
// Setup Motor 1 (TB6600)
#define DIR_PIN1 11
#define STEP_PIN1 12
#define ENA_PIN1 8
// Setup Motor 2 (A4988)
#define DIR_PIN2 4
#define STEP_PIN2 7
#define ENA_PIN2 10
// Setup All motors
#define MOTOR_INTERFACE_TYPE AccelStepper::DRIVER
const float PASSOS_POR_ROT = 200.0;  // Steps per rotation
const float GEAR_RATIO = 1.0;
const float PASSOS_POR_GRAU = (PASSOS_POR_ROT * GEAR_RATIO) / 360.0;
// Project Setup
#define pinorele 9
#define pinobotao 6
int valor_anterior = 1;  // Motor state variable (on/off)
const unsigned long delay_rele = 1500; //Relay activation delay
unsigned long inicioDelayRele = 0;
bool estadoDelayRele = false;
AccelStepper motor1(MOTOR_INTERFACE_TYPE, STEP_PIN1, DIR_PIN1);
AccelStepper motor2(MOTOR_INTERFACE_TYPE, STEP_PIN2, DIR_PIN2);
// Motor 2 Movement variables
long proxMotor2 = 0;
bool motor2Pausado = false;
unsigned long inicioTempoPausa = 0;
  Serial.println("Stepper motor control with Arduino Nano, A4988, and TB6600");
  //  Motor 1 Speed setup
  motor1.setMaxSpeed(1000);
  motor1.setSpeed(V1);
  //  Motor 2 Speed setup
  motor2.setMaxSpeed(500);
  motor2.setAcceleration(V2);
  // Enable drivers:
  pinMode(ENA_PIN1, OUTPUT);
  pinMode(ENA_PIN2, OUTPUT);
  digitalWrite(ENA_PIN1, LOW);  // LOW enables TB6600
  digitalWrite(ENA_PIN2, LOW);  // LOW enables A4988
  // Relay and button
  pinMode(pinorele, OUTPUT);
  pinMode(pinobotao, INPUT_PULLUP);
  // Check button press
  int valor = digitalRead(pinobotao);
  if (valor != 1) {
    valor_anterior = !valor_anterior;
    while (digitalRead(pinobotao) == 0) {
      delay(10);
  if (valor_anterior == 0) {
    // Moves motor 1
    motor1.runSpeed();
    // Motor 2 control (Angle)
    if (!motor2Pausado) {
      // Checks if Motor 2 got to destined position
      if (motor2.distanceToGo() == 0) {
        // Defines next position
        proxMotor2 += GRAUS * PASSOS_POR_GRAU; //(DEGREES * STEPS_PER_DEGREE)
        motor2.moveTo(proxMotor2);
        // Moves Motor 2
        motor2.run();
        // Motor 2 Stop
        motor2Pausado = true;
        digitalWrite(pinorele, LOW); // Makes shure relay is enabled
        inicioTempoPausa = millis(); // (startPauseTime = millis())
        // Starts delay to activate relay
        inicioDelayRele = millis(); // (startDelayRelay = millis())
        estadoDelayRele = true; // (StateDelayRele = true)
      // Checks if the motor has reached its end position and starts the relay delay
      if (motor2.currentPosition() == proxMotor2 && estadoDelayRele) {
        if (millis() - inicioDelayRele >= delay_rele) {
          digitalWrite(pinorele, HIGH); // Activates the relay after the delay
          estadoDelayRele = false;    // Stops the delay timer
      // Checks if the engine pause time has been reached
      if (millis() - inicioTempoPausa >= TEMPO) { //if (millis() - startTimePause >= TIME)
        digitalWrite(pinorele, LOW); // Disable relay after pause
    // Move Motor 2 to the target position
    motor2.run();
I’m out of ideas, haha, if anyone has a clue!
Thanks in advance!
Go back to the beginning.
Wire up just the arduino and power supply and one motor.
Write the simplest code to move that motor: hardwire Enable and Direction and only send the Pulse/Step signal.
Does that work? If not, figure out what's wrong. If it works, then go onto the next step: connect the Direction pin. Does that work? etc...
Looking at your Fritzing diagram, there are several issues. Try creating an annotated schematic—it will help you identify what you may have missed. I also recommend getting a few extra Arduinos, as it’s possible you’ve damaged the one you’re currently using.
Tks, I'm going back at it to try and pin point the issue.
I'll create a more appropriate schematic! But when you say issue, do you mean something specific you've noticed that's problematic about it?
When you see that happening then you should try swapping over the connections to one set of coils.
