PRFID Mod Parallax RFID reader
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
// Modified by Xenoepist for added functionality:
//  * Previous version double readed data. This happened because even thou the RFID reader had been deactivated after a data read
//    there was still data in the RFID reader buffer. The solution I implemented was to read this data and flush it.
//  * In this version, an Access list and a Master Key is added. The amount of keys in the access list is defined by the user with one simple modification.
//    At first the access list is empty, but the Master Key code should be manually entered in the program. To add keys to the
//    Access list, scan the master key once [Programming Mode] and then swipe the new key. If the new key is not in the access
//    list, the new key is added to the list. If the new key is alreadyt in the access list, then the key will be deleted from the access list.
//    If you entered programming mode by mistake, swipe the master key again to exit programming mode.
//  * Power it with a 12VDC 2.0Amp, to get enough juice to run VHG05 electronic lock. Also use an NPN transistor, with the base connected to pin 9
//  * Three LED Indicators are used to inform user of what is going on. If you want to modify the pins used, check the beggining of the code
//    under //LED Indicators. If you want to modify the behavior of these LED's, just change the end of the code, the last 5 functions controll
//    the behavior of the LED's.
//Constants
#define NumberOfKeys  10  //This defines the amount of keys in the access list
#define WAIT_TIME 2000     //Time door will remain open
#define BLINKS 3               //The amount of times the indicators blink when blinking is required
#define ON_TIME 200         //time in milliseconds the relay stays energized
//External Equipment
#define ENABLE 2               //Pin connected to the Enable pin of RFID
#define LOCK 9                  //Pin that is connected to NPN transistor that energizes lock
//LED Indicators
#define OPEN_LIGHT 4              //LED indicator. Indicates the correct key was entered
#define DENIED_LIGHT 5           //LED indicator. Indicates the wrong key was entered
#define PROGRAMMING_LIGHT 6 //LED indicator. Indicates Programming mode is activated
int     val = 0;
int     bytesread = 0;
String  Master = "0B082D041A";  //Stores the master key used for programming the other keys
String  empty = "0000000000";
String  keyCode;
String  accessList[NumberOfKeys];
char    code[10];
boolean programmingMode,isInAccessList,KeyFound = false;
pinMode(OPEN_LIGHT,OUTPUT);
pinMode(DENIED_LIGHT,OUTPUT);
pinMode(PROGRAMMING_LIGHT,OUTPUT);
pinMode(ENABLE,OUTPUT);
pinMode(LOCK,OUTPUT);
//Generates an array of size corresponding to the size of the access list
for(int i = 0;i<NumberOfKeys;i++){
  accessList[i] = empty;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
digitalWrite(OPEN_LIGHT,LOW);
digitalWrite(DENIED_LIGHT,LOW);
digitalWrite(PROGRAMMING_LIGHT,LOW);
digitalWrite(ENABLE, LOW);                  // LOW Activates the RFID reader, HIGH deactivates it
digitalWrite(LOCK,LOW);
   /**** EXTRACTION OF DATA FROM CARD ****/
  if(Serial.available() > 0) {            // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header [Header of data = 10]
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                             // stop reading
          code[bytesread] = val;      // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {                  // if 10 digit read is complete
      digitalWrite(ENABLE, HIGH);        // deactivate the RFID reader for a moment so it will not flood
       keyCode = code;
       keyCode = keyCode.substring(0,10);
       /*** INTERPRETATION OF DATA ***/
       //At this point, data was read, and there is a keycode in the keyCode variable
       if((keyCode == Master) && (programmingMode == false))
       {programmingMode = true;
        digitalWrite(PROGRAMMING_LIGHT,HIGH);
       {if(programmingMode == false)
          for(int i = 0;i<NumberOfKeys;i++)  //check entered key against saved keys
             if(keyCode.equals(accessList[i])){
                KeyFound = true;}                  //if the key is in the access list, KeyFound = true;
          if(KeyFound)
            accessGranted();
            KeyFound = false;
          else{
            accessDenied();
      else if(programmingMode)
        if(keyCode.equals(Master)){  //Master Key swipped during programming mode
        }else
         isInAccessList = false;               //this is an initialization value, if the key is in the access list, this variable will be true later.
          for(int i = 0;i< NumberOfKeys;i++)   //Scans Access List
            {if(keyCode.equals(accessList[i])) //if the card read is in the Access List
                accessList[i] = empty;         //delete it
                isInAccessList = true;         //isInAccessList set to true, meaning the key was in the access list
                keyDeleted();
           if(isInAccessList == false)             //if the key swipped is not in the access list and...
              for(int i = 0;i< NumberOfKeys;i++){
                if(accessList[i].equals(empty))    //...if current Access List Slot is Empty
                {accessList[i] = keyCode;          //Enter Key into Access List Slot
                newKeyEntered();
                if(i == (NumberOfKeys - 1))       //if you get to this point at last interation of loop, access List is full
                    listFull();
        programmingMode = false;                   //Programming is done, turn programming mode and indicator off
       resetIndicators();
    }    //end of data reading
/*** CLEARS DATA FROM BUFFERS TO AVOID DOUBLE READS***/
void flushBuffers(){
   while(Serial.available() > 0)          //if there is still data remaining in the RFID reader buffer
       Serial.read();                         //read it into arduino buffer
   Serial.flush();                             //then flush it
/*** RESETTING INDICATORS ***/
void resetIndicators(){
      delay(WAIT_TIME);                 //wait a little
      flushBuffers();                       //clear buffers
      digitalWrite(LOCK,LOW);              //return everything to starting position
      digitalWrite(ENABLE,LOW);
/*** BEHAVIOR OF LED INDICATORS IF A KEY IN THE ACCESS LIST IS SWIPPED ***/
void accessGranted(){
  digitalWrite(OPEN_LIGHT,HIGH);
  digitalWrite(LOCK,HIGH);//Sends 5V to transistor to energize door lock
  delay(ON_TIME);            //Relay stays energized for ON_TIME milliseconds
  digitalWrite(LOCK,LOW); //Immediately after delay, de-energize door.
/*** BEHAVIOR OF LED INDICATORS IF A KEY THAT'S NOT IN THE ACCESS LIST IS SWIPPED ***/
void accessDenied(){
  digitalWrite(DENIED_LIGHT,HIGH);
/*** BEHAVIOR OF LED INDICATORS IF A NEW KEY IS ENTERED IN THE ACCESS LIST ***/
void newKeyEntered(){
  for(int i = 0; i<BLINKS;i++)
      delay(250);
      delay(250);
/*** BEHAVIOR OF LED INDICATORS IF A KEY IS DELETED FROM ACCESS LIST ***/
void keyDeleted(){
      delay(250);
      delay(250);
/*** BEHAVIOR OF LED INDICATORS IF ACCESS LIST IS FULL ***/
void listFull(){
      delay(250);
      delay(250);
ohhhh........where were you 18 months ago. This would have been so helpful.
Sorry, unhappyelf, this is something I just started working on :~ Anyways, if you planned to use the code I posted before, please don't. Use the one that is there now. It's much better and has more functions. :)
Somehow i cant get a RDM6300 connected :(
Hello,
Pretty interesting topic and since I am a complete beginner in programming, got stuck understanding your code as follows:
  1. Why this line is necessary, some kind of data conversion? keyCode = keyCode.substring(0,10);
  2. What will happen here, if the first if statement is correct, the code will execute and else statement will be skipped, am I right? Actually what is the purpose of the first statement.
if((keyCode == Master) && (programmingMode == false)) {programmingMode = true; digitalWrite(PROGRAMMING_LIGHT,HIGH); } else {if(programmingMode == false)
Thanks in advace, Tom
Hi, sorry for the late response. It's been a looong time since I did anything with my arduino, really, but I will try to answer your questions.
1) I am actually pretty inexperienced programming the arduino myself; however I have some programming background in other languages so I don't really know what is going on in there, but if I remember correctly I used that because the first 10 characters of keycode were correct, but then after that it just gave me garbage, so I just extracted the first 10 digits. There should be a more elegant way to solve this problem, but I just did it like that.
2) Again, this can probably be written more elegantly, but just Interpret that statement like this if (you swipe the master key AND you are not in programming mode) [note both statements have to be true. NOT just one] enter programming mode and turn on the programming mode light [so the user knows we are in programming mode] else [note that at this point you can be in programming mode if the key you swiped previously was the master] if( you are NOT in programming mode)
This a very good work.
Im working with this at this moment and all are right, but i have a basic problem too hard for me, my system must be cut off the power, if the power fail are Cards store in memory are deleted and i need to store all again, is very dificult for me modify the code in order to save the ID cars in eeprom, can anyone help me??
Sorry for my poor english.
