primary expression error
Hello guys, I need help.
in this code
char key = Keypad.getKey();
it shows me this error message:
error: expected primary-expression before '.' token
I have been searching for solution for days, but couldn't find it.
I am a newbie into Arduino programming, so if you notice any mistakes please tell me.
Here is the full code:
#include <LiquidCrystal.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {5,4,3,2};
byte colPins[COLS] = {9,8,7,6};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int sensor1 = 10; // pin za senzor 1
int sensorValue1 = 0;
int mappedValue1;
LiquidCrystal lcd(10, 11, 12, 13, 14, 15, 16);
#define RELAY1 11
void setup(){
  lcd.begin(16, 2);
void loop(){
lcd.print; key;
sensorValue1 = analogRead(sensor1);
lcd.print("sensor 1 = " );
lcd.println();
lcd.println(sensorValue1);
lcd.println();
if (sensorValue1 < key)
digitalWrite(RELAY1, LOW);
if (sensorValue1 > key)
digitalWrite(RELAY1, HIGH);
I think this line
lcd.print; key;
needs some ( ), perhaps:
lcd.print (key);
Your instance name is NOT Keypad.
That was it!
I just changed Keypad.getKey into keypad.getKey and it worked.
Thanks guys!
Hello Everyone!
I am new with Arduino as well and I need to know what in the world is wrong with my code.
#include <Servo.h>
int servoPin = 10;
int seroPin = 9;
int servoPin = 6;
int servoPin = 3;
int servoPin = 5;
Servo servo;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
int angle = 0;
servo1.attach(10);
servo2.attach(9);
servo3.attach(6);
servo4.attach(3);
servo5.attach(5);
for(angle = 0; angle < 90; angle ++ 1;)
servo1.write(90);
servo2.write(90);
servo3.write(90);
servo4.write(90);
servo5.write(90);
It is giving me many different code errors...I really need your help.
Thanks
@gummy781
Do not ask your questions in other people's thread, start your own.
What's not working?
How are the servos wired?
What happens after the last } in loop() ?
How fast does loop() run ?
angle ++ 1; humm
Ok I am sorry, but I don't know how to do that.
a)absolutely nothing is working
b) the ground wires go to the Arduino and the other two wires go to the breadboard
c) I don't understand
d)what do you mean
e) is it =+ and what do they mean?
Draw a picture of all the wires. Post it.
servo1.write(90);
servo2.write(90);
servo3.write(90);
servo4.write(90);
servo5.write(90);
What is the point of looping when you do exactly the same thing on every iteration of the loop? Your for loop looks strange. The last term should be angle += 1 or angle++.
You need to learn what loop() does, then.
No, its += and it is a compound operator (look them up).
@gummy781 I Founded The Problem. Underlined Text Is The Problem. :
for(angle = 0; angle <= 90; angle += 1;)
servo1.write(90);
servo2.write(90);
servo3.write(90);
servo4.write(90);
servo5.write(90);
qwertfksonjsidjijsudfh:
well your better than me had the same error message
But I bet the code you didn't post is different.
