Primary expression error
Hello guys, I need help.
in this code
  Serial.println(temp);
it shows me this error message:
error: expected primary-expression before ';' token
I have been searching for solution for a while, but couldn't find it.
I am a newbie in the Arduino programming, so if you notice any mistakes please tell me.
const int ledPin = 3;
const int tsPin = A5;
float data, temp;
  pinMode(tsPin, INPUT);
  analogReference(INTERNAL);
  pinMode(ledPin,OUTPUT);
  data = analogRead(tsPin);
  temp = data * 100/1024*;
  Serial.println(tsPin);
  Serial.println(data);
  delay (1000);
  if(temp<30)
    digitalWrite(ledPin,LOW);
  else if (temp>80)
    digitalWrite(ledPin,HIGH);
This here is my full code
Hint:
temp = data * 100/1024*;   <-- ???
This type of error sometimes shows up on the wrong line of your code...
The error is in the line preceding the line indicated by the error. This is common in any compiler- always look at the preceding line if you can't see anything wrong with the line that the compiler decided there was an error.
Erik_Baas:
Hint:
i got it now thank you very much for the help!
