print first 10 characters of WiFi.SSID()
I want to read a network scan from my oled screen instead from the serial monitor. Because some network names are too long for my oled screen I want to display only the first 10 characters of WiFi.SSID()
How can I do that?
Can I make a .substring? Or should I choose another path?
What type of variable does WiFi.SSID() return ?
Please post a full program that illustrates what you are doing
Just a regular example wifi ScanNetworks sketch. How should I change Serial.println(WiFi.SSID(i)); to get only the first 10 characters of the SSID if the name is longer than 10 characters.
I have this script:
#include "ESP8266WiFi.h"
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  Serial.print("Scan start ... ");
  int n = WiFi.scanNetworks();
  Serial.print(n);
  Serial.println(" network(s) found");
  for (int i = 0; i < n; i++)
delay(5000);
WiFi.SSID returns an evil String.
Here's how I would do it. First I convert the return from WiFi.SSID to a real string, then use printf() to print the first ten characters.
char netid[33];       // Can hold an SSID up to 32 characters
  WiFi.disconnect();
  delay(100);
  Serial.print(n);
  for (int i = 0; i < n; i++) {
    strcpy(netid, WiFi.SSID(i).c_str());
    Serial.println(netid);
    printf("%.10s\n\n", netid);
You could use sprintf() or snprintf() to make a new string if that is what you need for your display.
"Can I make a .substring?"
You probably can. The below test code indicates that an SSID can be captured as a String. In the scan loop you probably could capture the SSID as a String, check the length, and if it is too long, use substring to get the part you want to display, and print that out.
    This sketch demonstrates how to scan WiFi networks.
    The API is almost the same as with the WiFi Shield library,
    the most obvious difference being the different file you need to include:
String readString; //String test
  // Set WiFi to station mode and disconnect from an AP if it was previously connected
  WiFi.disconnect();
  delay(100);
  Serial.println("Setup done");
  Serial.println("scan start");
  // WiFi.scanNetworks will return the number of networks found
  Serial.println("scan done");
  if (n == 0) {
    Serial.println("no networks found");
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i) {
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      readString = (WiFi.SSID(i)); //String test
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*");
      delay(10);
  Serial.println("");
  Serial.print("String SSID is "); //String test
  Serial.println(readString); //String test
  Serial.println("");
  // Wait a bit before scanning again
  delay(5000);
I added a substring operation in the test code below and it prints out the first part of the SSID, so it may fit your oled screen.
String newString; //String test
  WiFi.disconnect();
  delay(100);
  if (n == 0) {
    Serial.print(n);
      Serial.print(": ");
      //Serial.print(WiFi.SSID(i));
      newString = readString.substring(0, 11);
      Serial.print(newString);
      Serial.print(" (");
      Serial.print(")");
      delay(10);
  Serial.println("");
  Serial.println("");
  delay(5000);
zoomkat:
It works perfectly! Thank you.
