Hello,
this is kind of my first project and I'm trying to : take a log from a gps antena, parse it and only take the timestamp from it, then print it, then i want to take all the measurements from LiDAR untill a new time comes from gps antena.
this is my code:
#include <Wire.h>
#import "process_log.h"
#import "save_sd.h"
#import "lidar_measurements.h"
//initialize the liquid crystal library
//the first parameter is the I2C address
//the second parameter is how many rows are on your screen
LiquidCrystal_I2C lcd(0x3F,16,2);
// only some pins can be used for RX check SoftwareSerial docs
const int chipSelect = 10; //define chip select pin for microSD
#define GPS_RX_PIN 8 // pin rx for GPS
#define GPS_TX_PIN 9 // we don't use it (because we don't transmit anything) but it needs to be as a parameter for GPS serial
SoftwareSerial gpsSerial(GPS_RX_PIN, GPS_TX_PIN);
#define FAST_I2C
Serial.begin(9600); //initialize the serial communication at 9600 baud rate
gpsSerial.begin(9600); //serial for gps
// check if micro sd is plugged
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect))
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// Initialize Arduino I2C (for communication to LidarLite)
Wire.begin();
#ifdef FAST_I2C
#if ARDUINO >= 157
Wire.setClock(400000UL); // set I2C frequency to 400kHz (for Arduino Due)
#else
TWBR = ((F_CPU / 400000UL) - 16) / 2; // set I2C frequency to 400kHz
#endif
#endif
lcd.init();
lcd.clear();
lcd.backlight();
// declare vars as static to persist between loop iterations
static uint16_t distanceSum = 0;
static uint16_t distanceCount = 0;
static uint32_t lastSecond = 0;
uint32_t currentSecond = 0;
uint16_t distance;
uint8_t result_lidar = distanceFast(&distance);
Serial.println("result_lidar: " + result_lidar);
distanceSum += distance;
distanceCount++;
// Read data from GPS module if available
if (gpsSerial.available() > 0)
String data = processGPS(gpsSerial, lastSecond, distanceSum, distanceCount, currentSecond, distance);
// save_data_toSD(&data);
lcd.setCursor(0,0);
lcd.print("Time - Distance:");
lcd.setCursor(0,1);
lcd.print(data);
Serial.println(data);
this is working fine, because right now i'm taking one measurement and time for gps and print it
uint8_t distanceFast(uint16_t * distance)
myLidarLite.configure(0);
myLidarLite.waitForBusy();
myLidarLite.takeRange();
*distance = myLidarLite.readDistance();
return *distance;
this is sending the data with time and measuremetn
#include "process_log.h"
String processGPS(SoftwareSerial& gpsSerial, uint32_t& lastSecond, uint16_t& distanceSum, uint16_t& distanceCount, uint32_t& currentSecond, uint16_t& distance)
static String nmeaLog = "";
static String data = "";
unsigned long startTime = millis(); // store the current time
// check if GPS serial is available
while (millis() - startTime < 1000) // timeout period of 1 second
char incomingByte = gpsSerial.read();
// check if incoming byte is the start of a new NMEA log
if (incomingByte == '$')
nmeaLog = ""; // reset the string for a new log
data = "";
// check if the end of the log is reached
if (incomingByte == '\n')
if (nmeaLog.indexOf("RMC") > -1)
String time = getClock(nmeaLog);
data += String(time);
//calculate arithmetic mean fir the previous sec
currentSecond = time.substring(0,2).toInt() * 3600 + time.substring(2,4).toInt() * 60 + time.substring(4,6).toInt();
if (currentSecond != lastSecond && lastSecond != 0)
float meanDistance = distanceSum / (float)distanceCount;
data += ",";
data += meanDistance;
// Reset counters
distanceSum = distance;
distanceCount = 1;
lastSecond = currentSecond;
return data;
nmeaLog += incomingByte; // append the incoming byte to the current log
return "";
the output log looks like this :
15:51:13.736 -> 135113,32.00
but i want something like :
15:51:13.736 -> and here take all the measuremetn from lidar (around 50)
please help
