Print Function Result
Hello,
I want to understand why I cannot print the text from the function Ethernet.hardwareStatus() in the way attempted below.
Sure, i can do it using the if statement below, but what is the reason why i cannot simply output the result from this function in the same way as Ethernet.localIP() for instance? Of course, I don’t actually need to do it this way, but Im looking for the fundamental reason behind why I seem unable to do this, as i’m clearly missing something… Many thanks.
#include <Ethernet.h>
#include <SPI.h>
EthernetServer server(80);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 68);
//EthernetClient client;
char status = Ethernet.hardwareStatus;
// Start Ehternet
 Ethernet.begin(mac,ip);
 server.begin();
// Start Serial Port
 Serial.println("Setup...");
 Serial.println("ip is: ");
 Serial.println(Ethernet.localIP());
 Serial.println("DNS is: ");
 Serial.println(Ethernet.dnsServerIP());
//everthing works fine to this point.
//I cannot obtain the value from Ethernet.hardwareStatus() using the lines below.
 Serial.println("Ethernet Hardward Status is: ");
 Serial.println(Ethernet.hardwareStatus());
 Serial.println(status);
//"EthernetW5100" seems to be only detected through use of the if statement.
if (Ethernet.hardwareStatus() == EthernetW5100) {
   Serial.println("W5100 Ethernet controller detected.");
What happens when you try ?
What does the function return ?
Ethernet.hardwareStatus() returns a number that represents the status, not a string telling you what it is.
it returns either'
1
hardwareStatus returns the type EthernetHardwareStatus
because the method is declared as:
static EthernetHardwareStatus hardwareStatus();
and EthernetHardwareStatus is just an enumeration:
enum EthernetHardwareStatus {
EthernetNoHardware,
EthernetW5100,
EthernetW5200,
EthernetW5500
so you will get "numbers" 0 .. 3 ... no text.
See: Ethernet/Ethernet.h at master · arduino-libraries/Ethernet · GitHub
I see, thankyou.
This doesn't do what you think it does:
What you intended was probably:
char status = Ethernet.hardwareStatus();
I'm not sure that would actually work though as you're calling it before Ethernet.begin. Try it and see.
