Print int pointer array error
int temp;
int k=1;
int j=4;
int l=6;
int m= 5;
int n=45;
int *sorting[]= {k,j,l,m,n};
void arraysort();
char state1[]= "GRRRGRRR";
char state2[]= "RRGRRRGR";
char state3[]= "GGRRRRRR";
char state4[]= "RRGGRRRR";
char state5[]= "RRRRGGRR";
char state6[]= "RRRRRRGG";
char state7[]= "RGRRRGRR";
char state8[]= "RRRGRRRG";
char *previous[] = {state1, state2, state3, state4, state5, state6, state7, state8 };
Serial.println(previous[7]);
   for(int j=0;j<=4;j++){
   for(int i=0;i<=3;i++){
   if(sorting[i]<sorting[i+1]){
      temp=sorting[i];
      sorting[i]=sorting[i+1];
      sorting[i]=temp;
  Serial.println(sorting);
I'm coding Arduino mega board and need to print the above sorting array to check it's sorted right or wrong. thank you
Hello
Insert a Serial.println() at POI to see what happens.
You are not storing legit pointers in your array and likely getting a warning at compile time (enable all warnings in the preferences)
This would feel better:
int *sorting[]= {&k, &j, &l, &m, &n};
Of course if you have pointers you need to dereference to compare the values being pointed and not the memory addresses so that’s not OK
(I did not read your code past that point)
I'm getting an error sir. I cannot print any in the sorting array. can u help me sir. thanks a lot.
sir, what is the POI
POI = point of interrest, e.g. a counter or logic state
Post code, not pictures of code.
Post error messages, not pictures of error messages.
sir, i have posted the code. in error msg have too much lines. but i will post in this.
Arduino: 1.8.15 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\PC\Desktop\design project\project\testing_again\testing_again.ino: In function 'void setup()':
testing_again:38:28: error: no matching function for call to 'println(int*&)'
   Serial.println(sorting[0]);
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:233,
                 from sketch\testing_again.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:80:12: note: candidate: size_t Print::println(char) <near match>
     size_t println(char);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:80:12: note:   conversion of argument 1 would be ill-formed:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:81:12: note: candidate: size_t Print::println(unsigned char, int) <near match>
     size_t println(unsigned char, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:81:12: note:   conversion of argument 1 would be ill-formed:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:82:12: note: candidate: size_t Print::println(int, int) <near match>
     size_t println(int, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:82:12: note:   conversion of argument 1 would be ill-formed:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:83:12: note: candidate: size_t Print::println(unsigned int, int) <near match>
     size_t println(unsigned int, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:83:12: note:   conversion of argument 1 would be ill-formed:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:84:12: note: candidate: size_t Print::println(long int, int) <near match>
     size_t println(long, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:84:12: note:   conversion of argument 1 would be ill-formed:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:85:12: note: candidate: size_t Print::println(long unsigned int, int) <near match>
     size_t println(unsigned long, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:85:12: note:   conversion of argument 1 would be ill-formed:
exit status 1
option enabled in File -> Preferences.
You're trying to print a pointer.
The print function doesn't know how to do that.
You posted some code, but not the code that caused that particular error.
I'm new sir. I don't know to do it. this code doesn't compile and shows an error in the serial print of sorting array.
yes sir, that is the problem. how can I print it.
int temp;
int k=1;
int j=4;
int l=6;
int m= 5;
int n=45;
int *sorting[]= {&k,&j,&l,&m,&n};
void arraysort();
      temp=sorting[i];
      sorting[i]=temp;
There's nothing to be gained by here by printing the value of a pointer, unless you print all of the pointers.
The actual values of pointers are pretty meaningless to us humans.
What do you want the print to tell you?
sir, I don't want to print the pointer. I want the k,j,l,m,n value order in the sorting pointer array. I have doing bubble sorting and need to get the highest value variable to the sorting [0] position. in here I was defining the variable values as k=1, l=6. I want to add this knowledge to a project of mine. to actually using this, I need to sort the array with random variable locations inside it. so I need to print the k,j,l,m,n values through the sorting array. is there a way sir.
Just dereference the pointer then.
  Serial.println(*sorting[0]);
int temp;
int k=1;
int j=4;
int l=6;
int m= 5;
int n=45;
void arraysort();
   if(*sorting[i]<*sorting[i+1]){
      temp=*sorting[i];
      *sorting[i]=*sorting[i+1];
      *sorting[i]=temp;
   for (int i = 0; i < 5; i++) {
    Serial.println(*sorting[i]);
sir, the error is fixed. but the sorting won't happen. it prints the array but didn't have any kind of sorting. can u help me, sir? thank you a lot.
Your sort code looks off - at the end of each iteration, you should be reducing the size you sort over by one element, because a bubble sort will always end each pass with at least one element being in the right place.
yes of course. but it doesnt matter right. it will check all the array for 5 times. if the sorting was write it dont go to the inner loop. at least one variable need to change. but there isnt any kind of change. it just print the declared pattern only
get your bubble sort algorithm right...
int k = 1;
int j = 4;
int l = 6;
int m = 5;
int n = 45;
int *sorting[] = {&k, &j, &l, &m, &n};
const size_t sortingCount = sizeof sorting / sizeof sorting[0];
  for (size_t i = 0; i <= sortingCount - 1; i++) {
    for (size_t j = 0; j < sortingCount - i - 1; j++) {
      if (*sorting[j] > *sorting[j + 1]) {
        auto temp = *sorting[j];
        *sorting[j] = *sorting[j + 1];
        *sorting[j + 1] = temp;
  for (size_t i = 0; i < 5; i++) {
    Serial.print(*sorting[i]);
    Serial.write(' ');
void loop() {}
thank you sir. can you explain a bit of the program. I'm a newbie in Arduino
What is it you don't understand? there is almost nothing Arduino related there (besides the use of Serial).
the rest is standard C++ and standard bubble sort algorithm
