So the name isn't quite fully as descriptive as what I am trying to do. I have 8 tekscan force resistor sensors hooked up to 8 analog input on an arduino micro. What I really want to do is have each of these analog input values print in the serial monitor side-by-side on subsequent new lines. I have been looking and am so frustrated that I needed to post to fish for an answer.
for example I want something like this printing off serial monitor:
3.14 3.14 3.14 5.25 6.27...... (for all 8 analog inputs)
the numbers are arbitrary, they are supposed to represent the voltage reading I am getting from each of the sensors, with each new set of numbers representing the next analog input device.
For example I am using analog pins 1-8 on the micro and it should look like this:
A1input A2input A3input....
A1input A2input A3input.... etc.
Any help at all with how to do this would be greatly appreciated!!!!
Thank you, thank you!! my god that was easy and I feel like a fool now. I just couldn't for the life of me figure it out. Obviously I'm not a regular coder haha.
or the below. "\t" inserts a tab. maybe neater than a space. For pins A2....A5, just add the extra lines...
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// print column headers:
Serial.print("A0");
Serial.print("\t");
Serial.println("A1");
// the loop repaeats action over and over:
// read the voltage input on analog pins A0 and A1:
int sensorValue1 = analogRead(A0);
int sensorValue2 = analogRead(A1);
// Convert the analog readings (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltageA0 = sensorValue1 * (5.0 / 1023.0);
float voltageA1 = sensorValue2 * (5.0 / 1023.0);
// print out the value you read. Be aware that println adds a carriage return:
Serial.print(voltageA0);
Serial.print("\t");
Serial.println(voltageA1);
// 2 sec sampling rate if you are reading of a monitor:
delay(2000);
