Is there a way to format the numbers that you send out to the serial monitor.
So instead of the following:
Motor Output = 55
Motor Output = 105
you would get:
Motor Output = 55
Motor Output = 105
or
Motor Output = 055
Motor Output = 105
Motor Output = 55
Motor Output = 105
you would get:
Motor Output = 55
Motor Output = 105
or
Motor Output = 055
Motor Output = 105
Pass them through sprintf:
int mynum = 39;
char temp[5];
Serial.print("Number: ");
sprintf(temp,"%03d",mynum);
Serial.println(temp);
Number: 039
thx
Found this after some searching
float testFloat = 10.24;
char tBuffer[16];
Serial.println(dtostrf(testFloat,8,2,tBuffer));
testFloat = testFloat + 1.1;
Yep, sprintf doesn't have the float code (it's massive). dtostrf() is your friend in this case.
In dire straits I have been known to write:
// print three digit val, zero-filled
if (val < 100) Serial.print('0');
if (val < 10) Serial.print('0');
Serial.print(val);
-br
billroy:
In dire straits I have been known to write:// print three digit val, zero-filled
Serial.print(val);
-br
Perfectly legitimate, and nice and light and fast. Good for keeping the code small, and clean.
You could also generalise it:
void zprint(unsigned int value, unsigned int zeros)
unsigned long pad = 1;
while(zeros>0)
pad = pad * 10;
zeros--;
while(pad>value)
Serial.print("0");
pad = pad / 10;
Serial.print(value);
