I modified code originally posted by mem here (printing a double variable - #7 by mem - Syntax & Programs - Arduino Forum) to round a double before printing it to an LCD. You could easily modify this code to print to the Serial monitor, too.
/*Prints decimal to LCD
*Takes value, precision as arguments
*Rounds decimal
void printDouble(double val, byte precision) {
lcd.print (int(val));
if( precision > 0) {
lcd.print(".");
unsigned long frac, mult = 1;
byte padding = precision -1;
while(precision--){
mult *=10;
if(val >= 0){
frac = (val - int(val)) * mult;
//Rounding
if(((val-int(val))*mult*10)-frac*10>=5){
frac++;
else{
frac = (int(val) - val) * mult;
//Rounding
if(((int(val)-val)*mult*10)-frac*10>=5){
frac++;
unsigned long frac1 = frac;
while(frac1 /= 10){
padding--;
while(padding--){
lcd.print("0");
lcd.print(frac,DEC) ;
