Hi everyone, I'm using a Heltec ESP32 OLED Wifi Kit. I've spent some time getting the code to this point. It's very close! I would like some help getting some angle data from an MPU6050 IMU to print on my OLED through a loop. My code is below, I haven't included the setup and other stuff as I think that's working fine:
double FramesPerSecond(double seconds)
static double framesPerSecond;
framesPerSecond = (framesPerSecond * 0.9) + (1.0 / seconds * 0.1);
return framesPerSecond;
void DrawLinesAndGraphicsFrame(int val)
g_OLED.clearBuffer();
g_OLED.home();
g_OLED.drawFrame(0, 0, g_OLED.getWidth(), g_OLED.getHeight()); // border around display
// Draw some text into the frame
g_OLED.setCursor(3, g_lineHeight * 2 + 2); /
g_OLED.print("Hello");
g_OLED.setCursor(3, g_lineHeight * 3 + 2);
g_OLED.printf("World");
g_OLED.setCursor(3, g_lineHeight * 4 + 2);
g_OLED.printf("%03d", val); //
// Send Buffer
g_OLED.sendBuffer();
int fps = 0;
for (;;) // Forever loop
double dStart = millis() / 1000.0; // record the start time
DrawLinesAndGraphicsFrame(fps);
double dEnd = millis() / 1000.0; // record the completion time
fps = FramesPerSecond(dEnd - dStart); // calculate FPS rate
I can get the Hello, World and val printing on the OLED, but I can't seem to figure out how to get some other sensor data printing in the loop, e.g. the mpu6050.getAccX and others. I've included some code from the MPU6050 tockn library which works just fine if I check through serial monitor. But I can't seem to figure out how to display it on the OLED the same way the 'val' is.
long timer = 0;
mpu6050.update();
if(millis() - timer > 1000){
Serial.println("");
Serial.print("temp : ");Serial.println(mpu6050.getTemp());
Serial.print("accX : ");Serial.print(mpu6050.getAccX());
Serial.print("\taccY : ");Serial.print(mpu6050.getAccY());
Serial.print("\taccZ : ");Serial.println(mpu6050.getAccZ());
Serial.print("gyroX : ");Serial.print(mpu6050.getGyroX());
Serial.print("\tgyroY : ");Serial.print(mpu6050.getGyroY());
Serial.print("\tgyroZ : ");Serial.println(mpu6050.getGyroZ());
Serial.print("accAngleX : ");Serial.print(mpu6050.getAccAngleX());
Serial.print("\taccAngleY : ");Serial.println(mpu6050.getAccAngleY());
Serial.print("gyroAngleX : ");Serial.print(mpu6050.getGyroAngleX());
Serial.print("\tgyroAngleY : ");Serial.print(mpu6050.getGyroAngleY());
Serial.print("\tgyroAngleZ : ");Serial.println(mpu6050.getGyroAngleZ());
Serial.print("angleX : ");Serial.print(mpu6050.getAngleX());
Serial.print("\tangleY : ");Serial.print(mpu6050.getAngleY());
Serial.print("\tangleZ : ");Serial.println(mpu6050.getAngleZ());
Serial.println("\n");
timer = millis();
Any help would really be appreciated! Thank you!
