hello arduino forum
I am a complete noob to arduino. I want to print the data from the serial monitor to my lcd.
I have a 16x2 lcd (Gleichmann GE-C1602B-TMI-JT/R). I am using the arduino due. Here is my code and my wiring.
int fanPulse = 0;
unsigned long pulseDuration;
int pwmPin = 9;
pinMode(fanPulse, INPUT);
digitalWrite(fanPulse,HIGH);
void readPulse() {
pulseDuration = pulseIn(fanPulse, LOW);
double frequency = 1000000/pulseDuration;
Serial.print("pulse duration:");
Serial.println(pulseDuration);
Serial.print("time for full rev. (microsec.):");
Serial.println(pulseDuration*2);
Serial.print("freq. (Hz):");
Serial.println(frequency/2);
Serial.print("RPM:");
Serial.println(frequency/2*60);
analogWrite(3,20);
delay(5000);
readPulse();
analogWrite(3,50);
delay(5000);
readPulse();
analogWrite(3,100);
delay(5000);
readPulse();
analogWrite(3,200);
delay(5000);
readPulse();
analogWrite(3,255);
delay(5000);
readPulse();
Use lcd.print instead of Serial.print.
But don't use lcd.println instead of Serial.println .
Actually you can use it, and it will compile, but you won't like the results.
Don
I have updated my code but i still cant get it to work.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
int fanPulse = 0;
lcd.begin(16, 2);
int pwmPin = 9;
void readPulse() {
lcd.print("RPM:");
analogWrite(3,20);
delay(5000);
readPulse();
analogWrite(3,50);
delay(5000);
readPulse();
analogWrite(3,100);
delay(5000);
readPulse();
analogWrite(3,200);
delay(5000);
readPulse();
analogWrite(3,255);
delay(5000);
readPulse();
lcd.setCursor(0, 1);
lcd.print(millis() /1000);
What does that mean “can’t get it to work”? Quality of assistance is directly proportional to quality of information provided.
dhymers
November 13, 2015, 8:40pm
#6
Groove:
I'll append an instruction here, replace all instances of serial.print with lcd.print, you only replaced one. Does the LCD just say RPM?
If you want to see data on LCD and the serial you'll have to use both separately or stuff all the things you want to say in a string then call each one once. (?)
