Print_text and variable issue
Hello,
I have a variable like
float temp;
And I have an st7735s display, i want to display like Temp is: ( value of temp)
print_text(5,90,"Temp is:"+temp,1,ST77XX_WHITE); - But when I try this i fail.
Can someone help me get around this issue. I want the variable to stay in the same line as the text with same color and height.
You forgot to write what happens
1.) When I try just to plug in like
print_text(20,5,boost,5,ST77XX_GREEN);
-boost is a variable
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino: In function 'void loop()':
Displej-Test-Print_greske_skoro:87:19: error: cannot convert 'float' to 'char*'
And the error that I mentioned.
Displej-Test-Print_greske_skoro:89:33: error: invalid operands of types 'const char [13]' and 'float' to binary 'operator+'
   print_text(5,90,"Temp engine:"+temp,1,ST77XX_WHITE);
This is because this is not Javascript and you cannot just add float to const char pointer. Try dtostrf dtostrf() with Arduino - Convert float to string - YouTube
Cant get it to work
Intro
float p = 3.1415926;
float temp=myELM327.engineCoolantTemp();
float usis=myELM327.intakeAirTemp();
float ugrana=myELM327.manifoldPressure();
float pritisak=myELM327.absBaroPressure();
float granausis= (uint8_t)ugrana;
float kpa= (uint8_t)pritisak;
float boost=(granausis-kpa)/100;
dtostrf
dtostrf(temp,3,0,temp_1);
dtostrf(usis,4,0,usis_1);
dtostrf(boost,3,2,boost_1);
Print
print_text(20,5,boost_1,5,ST77XX_GREEN);
  print_text(70,50,"BAR",2,ST77XX_GREEN);
  print_text(5,90,"Temp engine:",temp_1,1,ST77XX_WHITE);
  print_text(5,100,"Temp usisa:",usis_1,1,ST77XX_BLUE);
  print_text(146,116,"AM",1,ST77XX_WHITE);
Issues
Displej-Test-Print_greske_skoro:92:18: error: 'temp_1' was not declared in this scope
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:92:18: note: suggested alternative: 'temp'
                  temp
Displej-Test-Print_greske_skoro:93:18: error: 'usis_1' was not declared in this scope
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:93:18: note: suggested alternative: 'usis'
                  usis
Displej-Test-Print_greske_skoro:94:19: error: 'boost_1' was not declared in this scope
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:94:19: note: suggested alternative: 'boost'
                   boost
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:99:40: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:102:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
exit status 1
Please show your whole code.
#include <SPI.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include "bitmaps.h"
#include "bitmapsLarge.h"
#include "BluetoothSerial.h"
#include "ELMduino.h"
#define TFT_CS        5
#define TFT_RST        4 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC         2
BluetoothSerial SerialBT;
#define ELM_PORT   SerialBT
#define DEBUG_PORT Serial
ELM327 myELM327;
uint32_t rpm = 0;
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
void setup(void) {
  Serial.print(F("Hello! ST77xx TFT Test"));
 tft.initR(INITR_BLACKTAB);
  tft.setRotation(0);
  tft.fillScreen(ST7735_BLACK);
#if LED_BUILTIN
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
#endif
  DEBUG_PORT.begin(115200);
  //SerialBT.setPin("1234");
  ELM_PORT.begin("ArduHUD", true);
  if (!ELM_PORT.connect("OBDII"))
    DEBUG_PORT.println("Couldn't connect to OBD scanner - Phase 1");
    while(1);
  if (!myELM327.begin(ELM_PORT, true, 2000))
    Serial.println("Couldn't connect to OBD scanner - Phase 2");
    while (1);
  Serial.println("Connected to ELM327");
//Case 2: Multi Colored Images/Icons
  int h = 160,w = 128, row, col, buffidx=0;
  for (row=0; row<h; row++) { // For each scanline...
    for (col=0; col<w; col++) { // For each pixel...
      //To read from Flash Memory, pgm_read_XXX is required.
      //Since image is stored as uint16_t, pgm_read_word is used as it uses 16bit address
      tft.drawPixel(col, row, pgm_read_word(evive_in_hand + buffidx));
      buffidx++;
    } // end pixel
  delay(5000);
  // Use this initializer if using a 1.8" TFT screen:
 // tft.initR(INITR_BLACKTAB);      // Init ST7735S chip, black tab
  tft.setRotation(1); // set display orientation
  tft.fillScreen(ST77XX_BLACK);
  float tempRPM = myELM327.rpm();
  if (myELM327.nb_rx_state == ELM_SUCCESS)
    rpm = (uint32_t)tempRPM;
    Serial.print("RPM: "); Serial.println(rpm);
  else if (myELM327.nb_rx_state != ELM_GETTING_MSG)
    myELM327.printError();
  delay(5000);
void print_text(byte x_pos, byte y_pos, char *text, byte text_size, uint16_t color) {
  tft.setCursor(x_pos, y_pos);
  tft.setTextSize(text_size);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(text);
Before use a variable you should declare it. Where are you declare temp_1, usis_1 and boost_1 ?
If i define it as string it still doesnt work.
Print worked just fine, and showed on display. ( wihout variables ofc.)
The easiest way to print a mixture of text and variables is to use separate print statements for each
What size of the strings you define?
  // Try adding these three lines at the top of loop()
  char temp_1[17];
  char usis_1[17];
  char boost_1[17];
Thanks, I've tried but i get errors when compiling.
I think this print won't work I will have to choose another way.
These two lines are also wrong. You can't put two strings in one print_text().
  print_text(5, 90, "Temp engine:", temp_1, 1, ST77XX_WHITE);
  print_text(5, 100, "Temp usisa:", usis_1, 1, ST77XX_BLUE);
You have to print the label and the value separately:
  print_text(5, 90, "Temp engine:",  1, ST77XX_WHITE);
  print_text(50, 90, temp_1, 1, ST77XX_WHITE);
  print_text(5, 100, "Temp usisa:", 1, ST77XX_BLUE);
  print_text(50, 100, usis_1, 1, ST77XX_BLUE);
Thanks, I just tired it. Don't work, I still get error when compiling. I will have to start from scratch.
I've tried it ditching dtostrf, and printing one under other doesnt work.
If you'd like any help with that, you know what to do.
When I put the code like this
#include <SPI.h>
#define TFT_CS        5
#define TFT_DC         2
ELM327 myELM327;
uint32_t rpm = 0;
void setup(void) {
  tft.setRotation(0);
#if LED_BUILTIN
#endif
    while(1);
    while (1);
      buffidx++;
    } // end pixel
  delay(5000);
  char temp_1[17];
  char usis_1[17];
  char boost_1[17];
   //D-to-string
  print_text(70,50,"BAR",2,ST77XX_GREEN);                 ////Boost
  print_text(70, 90, temp_1, 1, ST77XX_WHITE);            ///Engine_temp
  print_text(5, 100, "Temp usisa:", 1, ST77XX_BLUE);      ///Intake_temp
  print_text(70, 100, usis_1, 1, ST77XX_BLUE);
  delay(5000);
I get these errors
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 40MHz, 4MB (32Mb), 921600, Core 1, Core 1, None"
Displej-Test-Print_greske_skoro:109:3: error: 'print_text' was not declared in this scope
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:109:3: note: suggested alternative: 'sbintime_t'
   sbintime_t
Displej-Test-Print_greske_skoro:131:14: error: expected '}' at end of input
   delay(5000);
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:92:13: note: to match this '{'
exit status 1
option enabled in File -> Preferences.
EDIT: Here I was missing curly bracket
When I ditch d to string and char
code be like this
#include <SPI.h>
#define TFT_CS        5
#define TFT_DC         2
ELM327 myELM327;
uint32_t rpm = 0;
void setup(void) {
  tft.setRotation(0);
#if LED_BUILTIN
#endif
    while(1);
    while (1);
      buffidx++;
    } // end pixel
  delay(5000);
  print_text(70, 90, temp, 1, ST77XX_WHITE);            ///Engine_temp
  print_text(70, 100, usis, 1, ST77XX_BLUE);
  delay(5000);
  tft.print(text);
I get this error
Displej-Test-Print_greske_skoro:97:19: error: cannot convert 'float' to 'char*'
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:122:47: note:   initializing argument 3 of 'void print_text(byte, byte, char*, byte, uint16_t)'
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:98:40: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:100:53: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Displej-Test-Print_greske_skoro:101:22: error: cannot convert 'float' to 'char*'
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:103:51: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Displej-Test-Print_greske_skoro:104:23: error: cannot convert 'float' to 'char*'
C:\Users\X260\Documents\Arduino\Displej-Test-Print_greske_skoro\Displej-Test-Print_greske_skoro.ino:106:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
exit status 1
That's an easy one to figure out. Put the expected '}' at the end of the file.
If only there was a way to convert a 'float' variable to a character array. Oh yes! dtostrf(float,3,0,charBuffer);
