print values from a string
hi.
i have 3 varaibles in a string:
char motor_one_pins[]= "dirA1" "dirB1" "pwm1";
i want to print them in one line one by one. so the output will be:
dirA1, dirB1, pwm1
the actual code looks like that:
int motor_one(){
and i want the function "motor_one" to return "dirA1, dirB1, pwm1" so the function ahead will get these pins numbers:
void move_forward(int pinA, int pinB, int speed){
wheels_pwm.setPWM(pinA, 0, angleToPulse(0) );
wheels_pwm.setPWM(pinB, 0, angleToPulse(0) );
wheels_pwm.setPWM(pwm1p, 0, angleToPulse(speed) );
so when i call her it will look like this:
move_forward(put here the string);
so the final result will be "move_forward(dirA1, dirB1. pwm1);"
is there a way?
i use these 3 vars a lot in my code in the same order and want to do a little shortcut.
thanks!
char motor_one_pins[]= "dirA1" "dirB1" "pwm1";The effect of that definition is the following single string - "dirA1dirB1pwm1"
(you can verify that by printing the string)
What a bizarre way to hold 3 strings
Did you mean them to be in separate array levels ?
How about
char * motor_one_pins[] = {"dirA1" , "dirB1", "pwm1"};
  while (!Serial);
  for (int x = 0; x < 3; x++)
    Serial.println(motor_one_pins[x]);
