print with Serial.println value push button
Hi, I get issues when I pressed button. I don't get any value for console. Any rare character as $,aa but not as boolean 1 or 0 as I have written on my code. I try with Serial.println
Other problem.
When I charged my code always get the relay turn on. I want my relay turn off with respect on the led if is on or off.
/* Relays */
#define PUMP_PIN D6 //PUMP (Red LED)
#define LAMP_PIN D7 //LAMP (Green LED)
boolean pumpStatus = 0;
boolean lampStatus = 0;
/* Buttons */
#define PUMP_ON_BUTTON D9 //push-button PUMP (Red)
#define LAMP_ON_BUTTON D10 //push-button LAMP (Green)
  delay(10);
  Serial.println("ArduFarmBot 2");
  Serial.println(".... Starting Setup");
  Serial.println("  ");
  pinMode(PUMP_PIN, OUTPUT);
  pinMode(LAMP_PIN, OUTPUT);
  pinMode(PUMP_ON_BUTTON, INPUT_PULLUP);
  pinMode(LAMP_ON_BUTTON, INPUT_PULLUP);
  digitalWrite(PUMP_PIN, LOW);
  digitalWrite(LAMP_PIN, LOW);
  readLocalCmd();
* Read local commands (Pump and Lamp buttons are normally "HIGH"):
void readLocalCmd()
  boolean digiValue = debounce(PUMP_ON_BUTTON);
  Serial.println(digiValue);
  if(!digiValue)
    pumpStatus = !pumpStatus;
    aplyCmd();
  digiValue = debounce(LAMP_ON_BUTTON);
  if(!digiValue)
    lampStatus = !lampStatus;
    aplyCmd();
* Receive Commands and act on actuators
void aplyCmd()
  if(pumpStatus == 1)
    digitalWrite(PUMP_PIN, HIGH);
  if(lampStatus == 1)
    digitalWrite(LAMP_PIN, HIGH);
* Debouncing a key
boolean debounce(int pin)
  boolean state;
  boolean previousState;
  const int debounceDelay = 30;
  previousState = digitalRead(pin);
  for(int counter=0; counter< debounceDelay; counter++)
    delay(1);
    state = digitalRead(pin);
    if(state != previousState)
      counter = 0;
      previousState = state;
  return state;
Have you configured the serial console with a baud rate to match this? :
