I have a variable being assigned in the loop and it could be a 1 digit, 2 digit, or 3 digit number.
How can I print it so that it's always a 3 digit number?
For instance,
if the variable is 7, I need it to print out as 007
if the variable is 32, I need it to print out as 032
char buffer [50];
int n, a=4;
// n=sprintf (buffer, "%03d",a);
n = Pad(buffer, a);
Serial.println(buffer);
int Pad(char *str, int val)
char temp[4];
int len;
itoa(val, temp, 10);
len = strlen(temp);
switch (len) {
case 1:
strcpy(str, "00");
strcat(str, temp);
case 2:
strcpy(str, "0");
strcat(str, temp);
case 3:
strcpy(str, temp);
default:
len = -1;
return len;
The sprintf() version uses 3034 bytes while the other version uses 2130 bytes. If you don't need all of the power found in sprintf(), the alternative can save you some memory.
