I want to print a float variable with a maximum value of 99.9. I am using sprintf() but somehow end up with a ? only. Any help welcome ! Code is given below :
// Trial to print floating point value to a 16x2 LCD
#include <LCD.h>
#include<LiquidCrystal_I2C.h>
#include "Wire.h"
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7); // 0x27 is the I2C bus address
float volts = 99.9;
int cdtSec = 999;
char LCDmsg[16];
lcd.begin(16, 2);
lcd.setBacklightPin(3,POSITIVE);
lcd.setBacklight(HIGH);
lcd.clear();
delay(2000);
sprintf(LCDmsg, "VOLT:%04.1fSEC:%03u", volts, cdtSec);
lcd.print(LCDmsg); // resulting display " VOLT: ?SEC:999"
Hi Mogaraghu
Floats and in sprintf() don't work on the Arduino. You could use dtostrf() instead.
http://www.hobbytronics.co.uk/arduino-float-vars
Regards
Ray
As Hackscribble pointed out, something like (I don't have an LCD display handy):
#include <LCD.h>
#include "Wire.h"
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7); // 0x27 is the I2C bus address
float volts = 99.9;
int cdtSec = 999;
char LCDmsg[21];
dtostrf(volts, 4, 1, LCDmsg);
Serial.print("VOLT:");
Serial.print(LCDmsg);
Serial.print(" SEC: ");
Serial.println(cdtSec);
Try this simple function I wrote for a solar cell tester, its rude & crude but worked for what I was doing.
example:
lcd.setCursor(1,0);
lcd.print("Volts");
lcdNumFlt(volts,10,0,2,2);
// Call with number to display (FLOAT), decimal point column,
// line number (0 or 1),number of columns after DP (start with 4),
// number of columns after decimal point (try 3)
void lcdNumFlt (float num, byte dpcol, byte line, byte bdp, byte adp)
long tmp;
byte offset = 1;
tmp = num;
while(abs(tmp) >= 10){
tmp /= 10;
offset ++;
if(num < 0) offset ++;
lcd.setCursor(dpcol - bdp, line);
for(byte i = 0;i < bdp + adp + 1;i ++)
lcd.print(" ");
lcd.setCursor(dpcol - offset, line);
lcd.print(num, adp);
Feel free to crack, hack and repack.
Hackscribble:
Hi Mogaraghu
Floats and sprintf() don't work on the Arduino. You could use dtostrf() instead.
Regards
Ray
Perfect. The idea worked and I got the required display on the LCD. It is not that sprintf() does not work at all in Arduino - just that it cannot handle a float I guess. Thanks for the tip - it was a critical point. This is the code snippet I used :
#include <LCD.h>
#include "Wire.h"
float volts = 12.3;
int cdtSec = 456;
char LCDmsg[16];
lcd.begin(16, 2);
lcd.clear();
delay(2000);
sprintf(LCDmsg, "VOLT: SEC:%03u",cdtSec);
lcd.print(LCDmsg);
lcd.setCursor(5,0);
dtostrf(volts,4,1,LCDmsg);
lcd.print(LCDmsg);
