Printing an array to node-red text dashboard node
Hi. Im currently working on a project that scans for networks, as of now i’ve made it print the networks all at the same time. My problem is that I can’t send the data into node-red via text node. It gives me an error that involves converting the variables.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const int array2Size = 100;
String checkPass2[array2Size];
const int arraySize = 5;
int checkPass[arraySize]; // all elements are zero.
const char* ssid = "Tenda_FE2038";
const char* password = "huertas032793";
String sssid;
uint8_t encryptionType;
int32_t RSSI;
uint8_t* BSSID;
int32_t channel;
bool isHidden;
uint8_t prevRssi;
const char* mqtt_server = "192.168.1.2";
// Initializes the espClient. You should change the espClient name if you have multiple ESPs running in your home automation system
WiFiClient espClient;
PubSubClient client(espClient);
// Timers auxiliar variables
long now = millis();
long lastMeasure = 0;
void callback(String topic, byte* message, unsigned int length) {
 // Serial.print("Message arrived on topic: ");
  Serial.print(topic);
  Serial.print(". Message: ");
  String messageTemp;
  for (int i = 0; i < length; i++) {
    Serial.print((char)message[i]);
    messageTemp += (char)message[i];
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // Subscribe or resubscribe to a topic
      // You can subscribe to more topics (to control more LEDs in this example)
     // client.subscribe("rssi/test");
      client.subscribe("name/test");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
   Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
if (!client.connected()) {
    reconnect();
  if(!client.loop())
    client.connect("ESP8266Client");
   byte available_networks = WiFi.scanNetworks();
        int netnum = 0;
     for (int network = 0; network < available_networks; network++)
    checkPass2[network] = WiFi.SSID(network);
    checkPass[network] = WiFi.RSSI(network);
    netnum = network;
    prevRssi = (uint8_t)WiFi.RSSI(network);
    //Serial.println(checkPass[network]);
   delay (1000);
    Networks();
  void Networks()
    byte avail_net = WiFi.scanNetworks();
  for(int i = 0; i < avail_net ; i ++){
     Serial.println(checkPass[i]);
     Serial.println(checkPass2[i]);
     client.publish("name/test",checkPass[i]);
This is the code that i’m working on. Sorry if it’s a bit messy, ive been trying a few thing to make it work. It gives me an error that says invalid conversion from int to const char*. Im pretty new to node-red and programming at all so I can’t figure out whats the problem by myself. The flow doesn’t need to be elegant I just need the SSID, RSSI of each network posted and updated everytime the loop is finished.
