Printing an uint8_t Using lcd.print
How do i print an uint8_t using lcd.print ? My C is a little rusty so I've forgotten how to do this.
This is the code which receives data from a radio module. I've left out all the irrelevant stuff. I'm using the VirtualWire library
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
     lcd.print(buf);
I tried casting but that didn't work. I don't know whether buf is null terminated and this could be a problem. Using lcd.write to print out individual characters until I reach buflen -1 works fine
It isn't.
"it didn't work" means that something happened, but you couldn't be bothered to tell us what, and that that differs from what you want. How are we then supposed to help you?
Ok, what I should have said is that it didn't compile.
I get these error messages:
Arduino: 1.5.5 (Windows Vista), Board: "Arduino Leonardo"
radiomodulereceive.ino: In function 'void loop()':
radiomodulereceive:55: error: call of overloaded 'print(uint8_t [30])' is ambiguous
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:56: note: candidates are: size_t Print::print(const String&)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:57: note: size_t Print::print(const char*)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:58: note: size_t Print::print(char)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:59: note: size_t Print::print(unsigned char, int)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:60: note: size_t Print::print(int, int)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:61: note: size_t Print::print(unsigned int, int)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:62: note: size_t Print::print(long int, int)
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:63: note: size_t Print::print(long unsigned int, int)
That's a completely different story. How did you try to cast the value?
       buf[buflen] = '\0'; // NULL terminate the array
       lcd.print((char *)buf);
That worked fine, thanks for the help!
