Printing binary
How do I get the Serial.print(myByte, BIN); statement to print out the whole byte and not truncate the leading zeros if they are part of the byte?
I need a list of all eight digits in the byte that prints including zero in the MSB end.
You can't unless you modify the underlying Serial class.
void printBinary(byte inByte)
  for (int b = 7; b >= 0; b--)
    Serial.print(bitRead(inByte, b));
Please don't hijack unrelated threads.
Topic split
There is NO difference between 10 and 00000010. If you want to see 00000010 as the output, you have two choices - use bitRead() and output the result, in a loop over all the bits of the byte, OR use sprintf() to populate a string with leading 0s and print the string.
Thanks for the help. I had concluded the same as the above comments. I just was disappointed that there wasn't a direct way to do this simple task. Most programmers don't deal with machine code and working with logic gates, but when you do, partial byte read-outs are really frustrating. Truncation is great for financial transactions, but not when recording byte streams for analysis.
Why not print in Hex ? It is often easier to read and interpret than binary and does not involve counting ones and zeroes.
