Printing characters via serial Digole OLED LED LCD Display
I tried to send a text via serial port on Digo but it only display 0. Instead, If I send L1, L2, L332 it shows just fine. What should I change? Or what did I do wrong. I have attached the code. http://www.digole.com//images/file/Tech_Data/Digole_Serial_Display_Adapter-Manual.pdf
/*----------NOTE----------
      UART  I2C    SPI
OLD   8998  8988   9132
NEW   6966  7566   6354
int state;
#define _Digole_Serial_I2C_  //To tell compiler compile the special communication only,
#include <DigoleSerial.h>
#if defined(_Digole_Serial_I2C_)
#include <Wire.h>
DigoleSerialDisp mydisp(&Wire,'\x27');  //I2C:Arduino UNO: SDA (data line) is on analog input pin 4, and SCL (clock line) is on analog input pin 5 on UNO and Duemilanove
#endif
#define LCDCol 16
#define LCDRow 2
#define SC_W 160  //screen width in pixels
#define SC_H 128  //screen Hight in pixels
void resetpos(void) //for demo use, reset display position and clean the demo line
    mydisp.setPrintPos(0, 1, _TEXT_);
    delay(1500); //delay 2 seconds
    mydisp.println("                "); //display space, use to clear the demo line
    mydisp.begin();
    /*----------for text LCD adapter and graphic LCD adapter ------------*/
    mydisp.clearScreen(); //CLear screen
    //mydisp.displayConfig(1);    //set config display ON, 0=off
    // mydisp.setI2CAddress(0x27);  //this function only working when you connect using I2C, from 1 to 127
    //delay(1000);
    //mydisp.setLCDColRow(16,2);  //set LCD Col and Row, only time set up is OK
    mydisp.disableCursor(); //disable cursor, enable cursore use: enableCursor();
    mydisp.drawStr(3, 0, "Display ON"); //display string at: x=4, y=0
       if (Serial.available()>0) {
         if (Serial.peek() == 'L') {
           Serial.read();
          state = Serial.parseInt();
         mydisp.displayConfig(0);
         mydisp.println(state);
      while (Serial.available() > 0){ //Discard everything that we didn't expect
      Serial.read();
Redo (MODIFY button) your post using the "#" button to post the code to create a scrolling window for the code.
Just highlight the code and press the "#" button. Then click SAVE
Thanks
