Printing different characters in arduino IDE terminal
Hi, I am using Arduino nano board. I connected to GPRS modem and its working fine. I am able to send and received data to/from server. But except the data i am sending and receiving remaining data is in other characters. AT commands and their response are in different characters.
I am using two serial ports (one is Softwareserial) and baudrate set to 9600.
What could be the reason? I set the GPRS baudrate to 9600 using AT+IPR=9600.
PR©N˜j T+ŽQQõRµ¤(øEµêjÊU&¤*KXC§K
ÒÑ•±Éj¨
9¤µªHÔT$&N›—22.d‰‰UQé IP CLOSE
AT+CDNSORIP=0
OK
AT+CIPSTART="TCP","xxx.xx.xx.xx","747"
OK
AT+CIPSEND
OK
sending data from GPRS modem
CONNECT OK
+IPD6:hiii
The GPRS modem is probably configured for 7bits with parity instead of 8bits without parity.
What is the default parity set in arduino serial port?
See Serial.begin() - Arduino Reference
"The default is 8 data bits, no parity, one stop bit. "
Cheers!
i did that but still i am getting the same error
format: 8 data bits,no parity, one stop bit
parity: space(0)
in AT+ICF
RZ¤CC)-5þ
OK
OK
The server side code may be flawed.
OK. Thank you.
Is there any AT command which will alert when the server sends a message to the GPRS modem?
