Printing floating point numbers in serial
I am using this code I found in this forum:
void printDouble( double val, unsigned int precision){
// prints val with number of decimal places determine by precision
// NOTE: precision is 1 followed by the number of zeros for the desired number of decimial places
// example: printDouble( 3.1415, 100); // prints 3.14 (two decimal places)
   Serial.print (int(val));  //prints the int part
   Serial.print("."); // print the decimal point
   unsigned int frac;
   if(val >= 0)
     frac = (val - int(val)) * precision;
      frac = (int(val)- val ) * precision;
   int frac1 = frac;
   while( frac1 /= 10 )
       precision /= 10;
   precision /= 10;
   while(  precision /= 10)
       Serial.print("0");
   Serial.println(frac,DEC) ;
But I get this error on my program:
test.ino:25: error: cannot convert 'float (*)()' to 'double' for argument '1' to 'void printDouble(double, unsigned int)'
            printDouble(read_temperature,10000000);
How can I fix this?
Yes it is a function that returns float.
You don't get 10000000 decimal of precision. You only get a decimal number with 7 digits precision!
You do realise, I hope, that Serial supports printing float values?
But you didn't post your program.
We get that a lot.
"360modena_cs"
I'm hoping the "_cs" doesn't imply "computer science"
No! it does not mean computer science.
Thanks a lot!
