printing/getting angle from encoder
HP (QEDS-7163) Optical Incremental Encoder (256 CPR)
I would like to convert the position of my encoder to angle. I did the following but I am gettin still the position : var_degrees = ((360/256)*counter);
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
#define encoderPinA 2
#define encoderPinB 3
#define CPR 256
volatile int counter =0;
volatile boolean flag;
volatile int var_degrees =0;
  pinMode(encoderPinA, INPUT);
  pinMode(encoderPinB, INPUT);
  Serial.begin (9600);
  attachInterrupt(digitalPinToInterrupt(encoderPinA), isr_2, RISING);
  lcd.clear();
   if(flag == true){
        //Serial.println(counter);
        Serial.println(var_degrees);
        lcd.setCursor(0, 1);
        lcd.print("Position: ");
        lcd.setCursor(9, 1);
        lcd.print(var_degrees);
        flag = false;
//Interrupts
void isr_2(){
flag = true;
  if(digitalRead(encoderPinA) == HIGH){
    if(digitalRead(encoderPinB) == LOW){
      counter = counter -1; //COUNTER CLOCK WISE
    else{
      counter = counter +1; //CW
  else{
      counter = counter + 1; //CW
    else{
      counter = counter - 1 ; //CCW
You're getting "integer-math'ed" here - there may be other things, but this is definitely a problem:
360/255 is 1 in integer math. If you want to do floating point math, make one of the operands a float, eg (360/255.0)
What output are you getting? Does that explain the issue? You haven't posted what output you're getting... though your post reads as if you intended to.
Oh didn't know that!! I just changed it to var_degrees = ((360/256.0)*counter); and I just rotated the encoder 360 degrees and it seem to be outputting the right degree which is 360.
