Printing line numbers from serial output
Hi everyone
I have a question about count loops. Can anyone share some ideas on how I can “count” each line of data that is printed through the serial output?
While using a digital temperature sensor (TMP102), what I am trying to achieve is to get something like this via the serial output:
Line 1 Celsius: 27.12
Line 2 Celsius: 27.14
Line 3 Celsius: 27.11
etc. etc…
Any thoughts? I always have such a difficult time wrapping my head around counter loops…
Thanks so much! Below is the code that I have so far:
#include <Wire.h>
int tmp102Address = 0x48;
void setup(){
  Wire.begin();
void loop(){
  //print line number, and then in the same line the temperature reading
  serial.print("Line ");
  serial.print("X" );    //This is where the "X" would be replaced by the line number
  //to print the temperature reading:
  float celsius = getTemperature();
  Serial.print("Celsius: ");
  Serial.println(celsius);
  //Ideally, I would like to have output like:
  //  Line 1 Celsius: 27.12
  //  Line 2 Celsius: 27.14
  //  Line 3 Celsius: 27.11 etc. etc
float getTemperature(){
  Wire.requestFrom(tmp102Address,2);
  byte MSB = Wire.read();
  byte LSB = Wire.read();
  //it's a 12bit int, using two's compliment for negative
  int TemperatureSum = ((MSB << 8) | LSB) >> 4;
  float celsius = TemperatureSum*0.0625;
  return celsius;
#include <Wire.h>
long X;
Hi AWOL
thanks for your response. However, I think that your response got somehow truncated, since it only showed the addition of a "long X;" in your suggested code.
Could you please re-try when you get a chance?
Thanks!!
It wasn't truncated, it was a kick start. If you remove the quotes around the X you posted, and add the characters ++ after it, see what happens.
(BTW, "Serial" is spelt with a capital "S")
Thanks AWOL! Your tip helped me figure out how to make the counter work. Here’s the working code that I got :slight_smile:
Thanks again!
#include <Wire.h>
int counter = 0;
void setup(){
  Wire.begin();
void loop(){
  Serial.print("Line ");
  counter = counter + 1;
  Serial.print(counter);
  Serial.print(" " );
  return celsius;
to get a nice layout you could consider using tabs:
  Serial.print("Line:\t");
  Serial.print("\t" );
Just a simple change:
Instead of:
try:
  Serial.print(++counter);
