Printing many variables in the serial monitor
As the subject states, I want to print three variables one line on the serial monitor and then have them print again on a new line after.
This is my code
int pin, pin1, pin2;
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
  pin = analogRead(A0);
  pin1 = analogRead(A1);
  pin2 = analogRead(A2);
  Serial.println(pin + pin1 + pin2);
The serial monitor displays the sum of all three variables (pin + pin1 + pin2) instead I want them to be displayed separately (pin1, pin2, pin3)
I tried to use Serial.println(pin, pin1, pin2); but that gave me this error:
exit status 1
no matching function for call to 'UARTClass::println(int&, int&, int&)'
Why are you ADDING the values? It doesn't seem to difficult to figure out that you need to print them using separate calls to Serial.println().
Serial.print(pin);
Serial.print(pin1);
Serial.println(pin2)
marco_c:
Serial.print(pin);
Serial.print(pin1);
The problem with that is what does
1394578
mean?
Why not add the values, as do Frank and Earnest?
True, good catch Paul. You need to add a space between them :slight_smile:
Just more printing.
try this :
Serial.print(pin); Serial.print(" ");
Serial.print(pin1); Serial.print(" ");
