Printing on Max7219 from Ds1302 time module
Hi guys;
I starting learn the way Max7219 works. this is my first attemp.
#include "LedControlMS.h"
#define NumMatrix 1  // Cuantas matrices vamos a usar
#include <DS1302.h>
// Inicializacion del modulo.
DS1302 rtc(2, 3, 5);
Time t;
LedControl lc=LedControl(12,11,10, NumMatrix);
      for (int i=0; i< NumMatrix ; i++)
           lc.shutdown(i,false);
           lc.setIntensity(i,8);
           lc.clearDisplay(i);
    t = rtc.getTime();
        lc.writeString(0,t.date);
well, as you noticed , through "if" instruction is possible print all values.
 if (t.date == 1) lc.writeString("1");
 if (t.hour == 1) lc.writeString("1");
However this way, is awkward and inefficient define all numbers an characters.
¿Is it possible to print any kind of variables ( serial. analog , digital read etc..) using ledControl Ms library?
¿Would you share an clue or example how I must solve this problem?
You didn't provide a link to the library, so it is impossible to say for certain.
However, it seems obvious that the library provides a method to write strings, and C provides methods, such as itoa() and dtostrf() to convert integers and floats to strings. sprintf() provides a way to create a composite string, containing several ints, characters, strings, and literals.
