Printing on Serial but not on LCD
Hi! This Menu code was meant to run in Serial but I'm trying to transfer it on LCD. I added the library and change all Serial code to lcd codes but it displays nothing. I also tried to code them at the same time to display them both but both of them wont display anything. Until I narrow down the problem on code lcd.print() after adding this code the problem starts. Also I tried adding this code to different parts of my code and it prints if the code was place before "Menu definition" on setup. placing it after that wont display. Any ideas? TIA
P.S. I tried printing a basic code on the LCD alone and with the Serial and it prints fine. I also tried changing the lcd Library
#include <Wire.h> // Library for I2C communication
#include <LiquidCrystal_I2C.h> // Library for LCD
#include <ButtonDebounce.h> //Library for Debouncing Buttons
#include "Menu.h"
Menu MyMenu;
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 20, 4);
//The DOWN button
ButtonDebounce down(9, 75);
byte BtnDownState = 0;
byte BtnDownLastState = 0;
//The RIGHT button
ButtonDebounce up(8, 75);
byte BtnRightState = 0;
byte BtnRightLastState = 0;
//The ENTER button
ButtonDebounce select(10, 75);
byte BtnEnterState = 0;
byte BtnEnterLastState = 0;
  lcd.init(); //start LCD
  lcd.backlight(); //start LCD backlight
  //Menu definition (Title,Father,Down,Next)
  (*(MyMenu.GetMenuCell(0))).Set("WInSSEMBLY", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(8),MyMenu.GetMenuCell(1));
  (*(MyMenu.GetMenuCell(1))).Set("MCF", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(2),MyMenu.GetMenuCell(1));
  (*(MyMenu.GetMenuCell(2))).Set("MCR", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(3),MyMenu.GetMenuCell(2));
  (*(MyMenu.GetMenuCell(3))).Set("MCU", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(4),MyMenu.GetMenuCell(3));
  (*(MyMenu.GetMenuCell(4))).Set("ME", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(5),MyMenu.GetMenuCell(4));
  (*(MyMenu.GetMenuCell(5))).Set("MS", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(6),MyMenu.GetMenuCell(5));
  (*(MyMenu.GetMenuCell(6))).Set("MZ", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(7),MyMenu.GetMenuCell(6));
  (*(MyMenu.GetMenuCell(7))).Set("back", MyMenu.GetMenuCell(0), MyMenu.GetMenuCell(1),MyMenu.GetMenuCell(7));
  (*(MyMenu.GetMenuCell(8))).Set("CASSEMBLY", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(0),MyMenu.GetMenuCell(9));
  (*(MyMenu.GetMenuCell(9))).Set("MCF", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(10),MyMenu.GetMenuCell(9));
  (*(MyMenu.GetMenuCell(10))).Set("MCR", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(11),MyMenu.GetMenuCell(10));
  (*(MyMenu.GetMenuCell(11))).Set("MCU", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(12),MyMenu.GetMenuCell(11));
  (*(MyMenu.GetMenuCell(12))).Set("ME", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(13),MyMenu.GetMenuCell(12));
  (*(MyMenu.GetMenuCell(13))).Set("MS", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(14),MyMenu.GetMenuCell(13));
  (*(MyMenu.GetMenuCell(14))).Set("MZ", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(15),MyMenu.GetMenuCell(14));
  (*(MyMenu.GetMenuCell(15))).Set("back", MyMenu.GetMenuCell(8), MyMenu.GetMenuCell(9),MyMenu.GetMenuCell(15));
  Serial.print(">");
  Serial.println(  (*(MyMenu.GetSelectedMenuCell())).GetTitle()  );
  (*(MyMenu.GetSelectedMenuCell())).SetIsSelected(true);
  lcd.setCursor(0,0);
  lcd.print("Hello");
  lcd.setCursor(0,1);
  lcd.print("World!");
void loop() // The main loop (runs over and over again)
  up.update(); // read UP button
  down.update(); // read DOWN button
  select.update(); // read SELECT button
  BtnDownState = down.state();
  BtnRightState = up.state();
  BtnEnterState = select.state();
  //The DOWN button
  if (BtnDownState != BtnDownLastState) {
    if (BtnDownState == HIGH) {
      Serial.print(">");
      Serial.println(  (*(MyMenu.GetNextDownMenuCell(MyMenu.GetSelectedMenuCell()))).GetTitle()  );
  BtnDownLastState = BtnDownState;
  //The RIGHT button
  if (BtnRightState != BtnRightLastState) {
    if (BtnRightState == HIGH) {
      Serial.print(">");
      Serial.println(  (*(MyMenu.GetNextRightMenuCell(MyMenu.GetSelectedMenuCell()))).GetTitle()  );
  BtnRightLastState = BtnRightState;
  //The ENTER button
  if (BtnEnterState != BtnEnterLastState) {
    if (BtnEnterState == LOW) {
      if (  (*(MyMenu.GetMenuCell(0))).GetIsSelected()==true  ) {
        Serial.println("This is the WIND  info page");
      } else if (  (*(MyMenu.GetMenuCell(1))).GetIsSelected()==true  ) {
        Serial.println("This is the MCF info page");
      } else if (  (*(MyMenu.GetMenuCell(2))).GetIsSelected()==true  ) {
        Serial.println("This is the MCR info page");
      } else if (  (*(MyMenu.GetMenuCell(3))).GetIsSelected()==true  ) {
        Serial.println("This is the MCU info page");
      } else if (  (*(MyMenu.GetMenuCell(4))).GetIsSelected()==true  ) {
        Serial.println("This is the ME info page");
      } else if (  (*(MyMenu.GetMenuCell(5))).GetIsSelected()==true  ) { //UP ONE DIR
        Serial.println("This is the MS info page");
      } else if (  (*(MyMenu.GetMenuCell(6))).GetIsSelected()==true  ) {
        Serial.println("This is the MZ info page");
      } else if (  (*(MyMenu.GetMenuCell(7))).GetIsSelected()==true  ) {
        Serial.print(">");
        Serial.println(  (*(MyMenu.GetFatherMenuCell(MyMenu.GetSelectedMenuCell()))).GetTitle()  );
      } else if (  (*(MyMenu.GetMenuCell(8))).GetIsSelected()==true  ) {
        Serial.println("This is the COIL info page");
      } else if (  (*(MyMenu.GetMenuCell(9))).GetIsSelected()==true  ) {
      } else if (  (*(MyMenu.GetMenuCell(10))).GetIsSelected()==true  ) {
      } else if (  (*(MyMenu.GetMenuCell(11))).GetIsSelected()==true  ) { //UP ONE DIR
      } else if (  (*(MyMenu.GetMenuCell(12))).GetIsSelected()==true  ) {
      } else if (  (*(MyMenu.GetMenuCell(13))).GetIsSelected()==true  ) { //UP ONE DIR
      } else if (  (*(MyMenu.GetMenuCell(14))).GetIsSelected()==true  ) {
      } else if (  (*(MyMenu.GetMenuCell(15))).GetIsSelected()==true  ) {
        Serial.print(">");
  BtnEnterLastState = BtnEnterState;
Here are the hearders and cpp:
#ifndef MenuCell_h
#define MenuCell_h
#include "Arduino.h"
class MenuCell
  private:
    char* Title; // string
    MenuCell* Father; // not always needed if it was reference i need it every time !!!
    MenuCell* NextDown;
    MenuCell* NextRight;
    bool IsSelected;
  public:
    MenuCell();
    char* GetTitle(); //string
    MenuCell* GetFather();
    MenuCell* GetNextDown();
    MenuCell* GetNextRight();
    bool GetIsSelected();
    void SetIsSelected(bool _IsSelected);
    void Set(char* _Title, MenuCell* _Father, MenuCell* _NextDown, MenuCell* _NextRight);
#endif
#include "MenuCell.h"
MenuCell::MenuCell()
  IsSelected=false;
char* MenuCell::GetTitle()
  return Title;
MenuCell* MenuCell::GetFather()
  return Father;
MenuCell* MenuCell::GetNextDown()
  return NextDown;
MenuCell* MenuCell::GetNextRight()
  return NextRight;
bool MenuCell::GetIsSelected()
  return IsSelected;
void MenuCell::SetIsSelected(bool _IsSelected)
  IsSelected=_IsSelected;
void MenuCell::Set(char* _Title, MenuCell* _Father, MenuCell* _NextDown, MenuCell* _NextRight)
  Title = _Title;
  Father = _Father;
  NextDown = _NextDown;
  NextRight = _NextRight;
#ifndef Menu_h
#define Menu_h
#define byte uint8_t
#define MENUSIZE 15 //26 ELEMENTS
class Menu
  private:
    MenuCell ArrayMenuCell[MENUSIZE]; // An array of MenuCell objects using default constructor
                                      // 0 ... MENUSIZE-1
  public:
    Menu();
    MenuCell* GetMenuCell(byte index);
    MenuCell* GetNextDownMenuCell(MenuCell* current);
    MenuCell* GetNextRightMenuCell(MenuCell* current);
    MenuCell* GetFatherMenuCell(MenuCell* current);
    MenuCell* GetSelectedMenuCell();
    byte GetSize();
#endif
#include "Menu.h"
Menu::Menu()
MenuCell* Menu::GetMenuCell(byte index)
  return &ArrayMenuCell[index];
MenuCell* Menu::GetNextDownMenuCell(MenuCell* current)
  (*current).SetIsSelected(false);
  (*((*current).GetNextDown())).SetIsSelected(true);
  return (*current).GetNextDown();
MenuCell* Menu::GetNextRightMenuCell(MenuCell* current)
  (*((*current).GetNextRight())).SetIsSelected(true);
  return (*current).GetNextRight();
MenuCell* Menu::GetFatherMenuCell(MenuCell* current)
  (*((*current).GetFather())).SetIsSelected(true);
  return (*current).GetFather();
MenuCell* Menu::GetSelectedMenuCell()
  int i;
  for (i = 0; i < MENUSIZE; i = i + 1) {
    if (ArrayMenuCell[i].GetIsSelected()==true) {
      return &ArrayMenuCell[i];
  return &ArrayMenuCell[0]; //We assume that at position 0 is the root
byte Menu::GetSize()
  return MENUSIZE;
That’s a lot of code …. Some displays won’t initialise if memory is low ?
You first step should be to try one of the examples with the library to check you can print something to the display .
Have you done that , does it work - Yes .
Comment out much of that code ( all of loop ) so you can concentrate on the display aspect and again get that working ( use debug techniques such as print to serial port , light an led etc ) to check things happen as you expect .
Post up a wiring diagram ( not Fritzing ) and state which display you are using .
