Printing std::string over Serial with << operator
Hi, I have got following programming issue:
  1. I have a class called AFP (arbitrary fp)
  2. the AFP has got a method called toString(), which converts AFP type to std::string
  3. I want to print the AFP types via Serial
  4. Currently I am doing it this way ( c_str() converts std::string into char* ):
	AFP x;
string 	q = x.toString();
	Serial.print( q.c_str() );
the Serial.print( x.toString().c_str() ) does not work.
  1. Ideally I would be happy to do it as:
Serial << x << endl;
where Serial will be overloaded with something like (streaming.h lib):
template<class T>
inline Print &operator <<(Print &stream, T arg)
{ stream.print(arg); return stream; }
inline Print &operator <<(Print &obj, const AFP arg)
{ obj.print(arg.toString().c_str() ); return obj; }
I’ve seen the “Streaming C+±style Output with Operator <<” library, but I would need an advice how to actually fit my scenario into the above Print template…
What does this mean? It didn't compile? It printed "Happy Birthday, Monkey!" instead? It printed nothing? "It didn't work" is far too lame to deal with.
