Hi, is there another way for printing values more than (4294967292) ?
because now I use something like this:
float value;
Serial.print(value);
and I need to use like
Serial.printf("%.10f", value);
Any advice ?
I use Arduino IDE and RP2040
What variable type is the value of 4294967292 held in ?
Supposed is float.
What is the largest number that a float can be on the RP2040 ?
Does the number ever have any decimal places or is it always an integer ?
Ah, Is there a limitation for the number that a float can be on the RP2040 ??
Of course there is
How and where I should find the limitation for each type for the RP2040?
Sorry, I don't know, A datasheet, perhaps
However, if the number is a large as 4294967292 then a decimal place or two is not going to make significance difference to the value is it ?
Are you sure that you need to use a float ?
Ineed to use like Serial.printf("%.10f", value);
"%.10f".
You still have not answered the question as to why you are using a float. Is 4294967292 a float, or is it an integer ?
What exactly are you trying to do ? Where does the number 4294967292 come from, for instance ?
printing floats with Arduino has a "fundamental" flaw in that it expects any printed results to be expressible as an integer part and a decimal part. So:
float g = 1.23457e12;
Serial.println(g);
g = 3.14159e-15;
Serial.println(g);
Will print
ovf
0
Even though neither is the desirable output, and the actual numbers are well withing the range of allowed values for a float.
(The small number can be sort-of fixed, but who wants to look at "0.00000000000000314159" for Serial.print(g, 20);
"Real" printf has formats "%e" and "%g" to handle cases where scientific notation may be required. I don't know of any other workarounds for Arduino...
