Hello! I want to present you my first project based on Arduino. This is a mini printer made of lacer-cut plywood details.
The task of this printer is printing small images on stickers. If you are interested in this project or you have some questions, i will try to answer them
Transmitting the image data from computer to the miniprinter is a task for my programm based on JavaX swing.
In this program I can edit an image before printing and send some commands for debug. For working with COM port I used jssc library.
(Sorry for my English, it is not my mother tongue)
You should also factor in the laser cutting cost; most people don't own a laser cutter (though they are getting cheaper) - so they either have to find a maker/hacker space with one (so figure in fees for membership), find a local TechShop (no where near "low-cost") - or buy a laser cutter ($$$). Or use an online service, or maybe a friend owns one...
That said - if the parts aren't too small (or too complex - the gears seem the most intricate) - a scrollsaw might be able to be used, provided one was really careful and patient.
I've given thought in the past of getting a laser cutter - but two things about them (beyond the cost) keeps me from doing so:
Ventilation can be difficult (very important though, especially if cutting acrylic).
Longevity of tube (I don't think I would use such a machine often enough to get the maximum amount of life from the tube - tube-based CO2 laser cutters need to be used often to get the most life out of them - counter-intuitive, but true).
I've been looking at the inexpensive 40W laser cutters to see if they would be able to cut thru the 5.2mm lauan plywood with multiple passes. The cutters are getting popular enough now that online groups are forming.
The first prototype of this project was made without laser-cutter. I used Proxxon DS 230/E, it's a tiny jigsaw machine, that cheaper then any laser cutter - it costs some more then 200$.
This is a sample "hand-made" gear, and it works very good and stably:
Yegor_A:
it is a fantasties project you might make a http://www.instructables.com of
Can you post some additional photographs, front, side, rear, top, bottom with dimensions or view a PDF of the different components i wil make it with mine Prusa i3 3D printer
Why the gears are not posted immediately on the servos, I I do not abort your project just ask out intrested
