Hi, so i know this might be a bit unusual as most HID devices just need to send data that is then received by the Arduino but due to the nature of my project, i need it to receive data as well. To explain I'm using an Arduino UNO, and the HID device is a barcode scanner. The barcode scanner has a manual that when puts it in different modes. With other barcode scanners, I've been able to simple serial write to the rx pin of the scanner but unfortunately, i cannot with this setup. Is there a way to write to a HID using the USB host shield? My code is shown below, atm it is able to receive the barcodes that i scan fine but i need to write/print to it as well to put it in the correct more (the code that will be written to it will be strings)
//Modified from https://github.com/felis/USB_Host_Shield_2.0/issues/323
#include <NeoSWSerial.h>
#include <AltSoftSerial.h>
#include <usbhid.h>
#include <usbhub.h>
#include <hiduniversal.h>
#include <hidboot.h>
#include <SPI.h>
AltSoftSerial altSerial; //RX = 8; TX= 9 ; Unusable PWM = 10;
String content;
class MyParser : public HIDReportParser {
public:
MyParser();
void Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf);
protected:
uint8_t KeyToAscii(bool upper, uint8_t mod, uint8_t key);
virtual void OnKeyScanned(bool upper, uint8_t mod, uint8_t key);
virtual void OnScanFinished();
MyParser::MyParser() {}
void MyParser::Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf) {
// If error or empty, return
if (buf[2] == 1 || buf[2] == 0) return;
for (uint8_t i = 7; i >= 2; i--) {
// If empty, skip
if (buf[i] == 0) continue;
// If enter signal emitted, scan finished
if (buf[i] == UHS_HID_BOOT_KEY_ENTER) {
OnScanFinished();
// If not, continue normally
else {
// If bit position not in 2, it's uppercase words
OnKeyScanned(i > 2, buf, buf[i]);
return;
uint8_t MyParser::KeyToAscii(bool upper, uint8_t mod, uint8_t key) {
// Letters
if (VALUE_WITHIN(key, 0x04, 0x1d)) {
if (upper) return (key - 4 + 'A');
else return (key - 4 + 'a');
// Numbers
else if (VALUE_WITHIN(key, 0x1e, 0x27)) {
return ((key == UHS_HID_BOOT_KEY_ZERO) ? '0' : key - 0x1e + '1');
return 0;
void MyParser::OnKeyScanned(bool upper, uint8_t mod, uint8_t key) {
uint8_t ascii = KeyToAscii(upper, mod, key);
content = (char)ascii;
Serial.print(content);
altSerial.print(content);
void MyParser::OnScanFinished() {
// Serial.println(" - Finished");
Serial.println("");
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
MyParser Parser;
altSerial.begin(9600);
Serial.begin( 9600 );
Serial.println("Start");
if (Usb.Init() == -1) {
Serial.println("OSC did not start.");
delay( 200 );
Hid.SetReportParser(0, &Parser);
//content = "";
Usb.Task();
