I was wondering if it's possible to print what you type into a serial port on an LCD. I have it so it prints the byte it receives which I have no idea why it does that but it works so I'll post the code if you'd like to take a look and give me some pointers.
Do you mean a code like this? It’s in your Arduino software under examples. You can check out ladyada’s tutorial on LCDs if you are new to it.
* Displays text sent over the serial port (e.g. from the Serial Monitor) on
* an attached LCD.
#include <LiquidCrystal.h>
// LiquidCrystal display with:
// rs on pin 12
// rw on pin 11
// enable on pin 10
// d4, d5, d6, d7 on pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
// when characters arrive over the serial port...
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
Hmm, I'll test this code out now. Also, where are these tutorials?
Do you mean like the "LiquidCrystal - Serial Input" example at http://arduino.cc/en/Tutorial/LiquidCrystalSerial?
Don
I gave you one location in my previous post. There are also examples buried in your Arduino download. Mine are here: "C:\Arduino\arduino-0017\hardware\libraries\LiquidCrystal\examples"
Don
This code you posted is not working for me. Maybe it’s my wiring again
Was not my wiring I just made a few edits though.
Perhaps you should follow up on your other (Hardware | Troubleshooting) thread, where you thought you fixed your display problem.
Don
No, I fixed the code. It wasn't working right. The hardware problem was OK. :D
It looks as if the Hacktronics example and the code in reply #1 are written for an earlier version of LiquidCrystal than the one that comes with Arduino v0017.
If you are still having problems (I can't be sure from your posts) I suggest you take a look at the example sketches that come in the Arduino download.
Don
