Printing variable on state change only
Hello, I have a pretty simple question. I need to view the output of several pots on a LCD, but not in a continuous stream, just when it changes. I have some example code, but I'm embarrassed to say that it's just not enough. Can somebody use it in an example for me?
boolean PreviousValue;
void loop( void )
 boolean ThisValue;
 ThisValue = digitalRead( 7 );
 if ( ThisValue != PreviousValue )
   // Your print goes here.
   PreviousValue = ThisValue;
a refactored version of the code, I added a timestamp in the print to show when state change happened.
#define INPUTPIN 7
int previousValue = LOW;
void loop( void )
  int value = digitalRead( INPUTPIN );
  if ( value != previousValue )
    Serial.print(millis());
    Serial.print(" :  ");
    Serial.println(value);
     PreviousValue = value;
  // do other things here
give it a try ..
Thanks Rob,
Ill try that, it seems much more clear. :slight_smile:
you're welcome, let us hear if it works and how you used it in your project
