#include <ESP8266WiFi.h>
// Replace with your network credentials
const char* ssid = "";
const char* password = "";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output1State = "empty";
String output2State = "empty";
// Assign output variables to GPIO pins
const int output1 = 1;
const int output2 = 2;
// Initialize the output variables as outputs
pinMode(output1, OUTPUT);
pinMode(output2, OUTPUT);
// Set outputs to LOW
digitalWrite(output1, LOW);
digitalWrite(output2, LOW);
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /1/empty") >= 0) {
Serial.println("ROOM 1 empty");
digitalWrite(output1, HIGH);
} else if (header.indexOf("GET /1/occupied") >= 0) {
Serial.println("ROOM 1 occupied");
output1State = "occupied";
} else if (header.indexOf("GET /2/empty") >= 0) {
Serial.println("ROOM 2 empty");
digitalWrite(output2, HIGH);
} else if (header.indexOf("GET /2/occupied") >= 0) {
Serial.println("ROOM 2 occupied");
output2State = "occupied";
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #77878A;}</style></head>");
// Web Page Heading
client.println("<body><h1>ESP8266 WEB SERVER</h1>");
// Display current state, and ON/OFF buttons for GPIO 5
client.println("<p>ROOM 1 - State " + output1State + "</p>");
// If the output5State is off, it displays the ON button
if (output1State=="occupied") {
client.println("<p><a href=\"/1/empty\"><button class=\"button\">EMPTY</button></a></p>");
client.println("<p><a href=\"/1/occupied\"><button class=\"button button2\">OCCUPIED</button></a></p>");
// Display current state, and ON/OFF buttons for GPIO 4
client.println("<p>ROOM 2 - State " + output2State + "</p>");
// If the output4State is off, it displays the ON button
if (output2State=="occupied") {
client.println("<p><a href=\"/2/empty\"><button class=\"button\">EMPTY</button></a></p>");
} else{
client.println("<p><a href=\"/2/occupied\"><button class=\"button button2\">OCCUPIED</button></a></p>");
client.println("</body></html>");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
when I upload the code, while shown in the web server state empty will show occupied , state occupied will shown empty . Anything doing wrong ?
