println still not working after delai
Hello,
I m starting arduino, and i got stuck with the code below.
The led pulse are ok, but i got only the first 1 with my println.
I m sure I made a mistake, anyone can help me to understand it plz?
Thanks a lot
const int LED = 13;
int sleep = 300;
int eta = 1;
int end = 10;
    pinMode(LED,OUTPUT);
  while (eta < end)
    Serial.println(eta);
    code(eta);
    delay(sleep/2);
    eta++;
    if (eta == end)
      Serial.println("well done, you make a loop");
void code(int number) {
  for (int i = 1; i <= number; i++) {
    digitalWrite(LED,HIGH);
    delay(sleep);
    digitalWrite(LED,LOW);
    delay(sleep);
Does your LED have a current limiting resistor?
Hello,
Absolutly no idea, i havent add anything, i just use mother board and USB connector
i got the following output when I ran your code and the led was flashing
1
2
3
4
5
6
7
8
9
The code looks okay, that's why I asked about hardware.
ha, i m sure this is good news lol.
I have a macbook pro and arduino 1.8.13, but my mother board is elegon.
Elegon is maybe the problem.
Do you think about it ?
aarg:
const int LED = 13;
As the OP says
I am going to be generous and assume until told different that he/she is using the built in LED on pin 13 and, hence, it has a current limiting resistor on the board
As the OP saysI am going to be generous and assume until told different that he/she is using the built in LED on pin 13 and, hence, it has a current limiting resistor on the board
Probably, but i m working on it since about 30 min, i m not sure what is "resistor", but i ll better tomorrow :stuck_out_tongue:
Arduino Led circuit
telykin:
Sure, but isn't it Elegoo? I could be wrong. Anyway, this is really too vague a description of your hardware. Please tell us exactly what board you have. A link would be desirable.
Your problem is that after eta becomes equal to 10, this while loop...
 while (eta < end)
...is never true again. So nothing in the while “body” ever executes again.
Start loop() with...
eta = 1;
...if you want the loop to restart from 1 and count up to 9 again.
... but to simply learn about a code loop, you shouldn't put it in loop() because that is a loop within a loop, as you found out after the fact. Just put it in setup().
pcbbc:
 while (eta < end)
eta = 1;
I have change my eta=1 in the loop, and i got the same result
const int LED = 13;
int sleep = 300;
int end = 10;
   Serial.begin(9600);// initialisation de la communication
  int eta = 1;
  while (eta < end)
    code(eta);
    delay(sleep/2);
    eta++;
    if (eta == end)
    delay(sleep);
    delay(sleep);
aarg:
I made a try with all in the setup, no change
const int LED = 13;
int sleep = 300;
int end = 10;
     int eta = 1;
  while (eta < end)
    code(eta);
    delay(sleep/2);
    eta++;
    if (eta == end)
    delay(sleep);
    delay(sleep);
aarg:
I bougth this kit :
https://www.amazon.fr/gp/product/B01JCRFMRC/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
my board seem to be ELEGOO UNO R3
Thank for help
You can’t have tested the first example properly.
Your first code example will print the output “1..9” and then “well done, you make a loop” over and over ad infinitum.
Your second example will only do it once, since it is in setup, and setup only runs once.
Either:
a) you made a mistake and this is not the code you actually tried
b) we don’t properly understand what you mean by “ i got only the first 1 with my println.”
If you mean you only see “1” and no other output on the serial, then my guess would be you have a fault with your wiring. Try disconnecting the LED.
pcbbc:
Either:
I try it again with new usb port.
you can look at it here : https://streamable.com/rfsgvt
the first 1 was already print from other try.
the led still right, but my printl no.
I teach ESL so I am not criticizing your English, but it is almost unintelligible. As bad as it is, I think if you clearly express yourself in your native language, and then use Google translate, it would be easier for English speakers to understand your posts.
It's nearly impossible to make sense out of statements like, "the first 1 was already print from other try." 1 what? What other try? Try what? etc...
The videos are not helpful because, who has the time to sit through minutes and minutes of blah?
aarg:
Sorry for my english, i will try google translation.
The video lasts just 40 seconds, it shows that the LED 13 flashes well and that tx also lights up correctly.
The only thing that doesn't work is the display in the console.
Finally, the first 1 is displayed, but then nothing.
I tried on different USB port, I get the same result.
I use an elegoo R3 card, a macbook pro and version 1.8.13 of arduino.
A person in the previous messages to test my code and it obviously works correctly on his side.
I no longer have too much idea to make the display work properly in the console.
Ah, then what happens when you upload and run the Serial examples that ship with the IDE?
Hello,
I tried the code below, its name is ASCII table.
And I think the result I get is not complete
  ASCII table
  Prints out byte values in all possible formats:
  - as raw binary values
  - as ASCII-encoded decimal, hex, octal, and binary values
  For more on ASCII, see http://www.asciitable.com and http://en.wikipedia.org/wiki/ASCII
  The circuit: No external hardware needed.
  created 2006
  by Nicholas Zambetti <http://www.zambetti.com>
  modified 9 Apr 2012
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/ASCIITable
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // prints title with ending line break
  Serial.println("ASCII Table ~ Character Map");
// first visible ASCIIcharacter '!' is number 33:
int thisByte = 33;
// you can also write ASCII characters in single quotes.
// for example, '!' is the same as 33, so you could also use this:
// int thisByte = '!';
  // prints value unaltered, i.e. the raw binary version of the byte.
  // The Serial Monitor interprets all bytes as ASCII, so 33, the first number,
  // will show up as '!'
  Serial.write(thisByte);
  Serial.print(", dec: ");
  // prints value as string as an ASCII-encoded decimal (base 10).
  // Decimal is the default format for Serial.print() and Serial.println(),
  // so no modifier is needed:
  Serial.print(thisByte);
  // But you can declare the modifier for decimal if you want to.
  // this also works if you uncomment it:
  // Serial.print(thisByte, DEC);
  Serial.print(", hex: ");
  // prints value as string in hexadecimal (base 16):
  Serial.print(thisByte, HEX);
  Serial.print(", oct: ");
  // prints value as string in octal (base 8);
  Serial.print(thisByte, OCT);
  Serial.print(", bin: ");
  // prints value as string in binary (base 2) also prints ending line break:
  Serial.println(thisByte, BIN);
  // if printed last visible character '~' or 126, stop:
  if (thisByte == 126) {    // you could also use if (thisByte == '~') {
    // This loop loops forever and does nothing
    while (true) {
      continue;
  // go on to the next character
  thisByte++;
