There is a problem with the code below. It did work before but now suddenly doesn't. I have tried this on several computers with the same error message - printTemperature not declared in this scope
File: readTemperature.ino
* Author: Andy Gelme (@geekscape) & Angus Gratton (angus at freetronics. com)
* License: GPLv3
* For more information see www.freetronics.com/irtemp
#include "IRTemp.h"
static const byte PIN_DATA = 2; // Choose any pins you like for these
static const byte PIN_CLOCK = 3;
static const byte PIN_ACQUIRE = 4;
static const TempUnit SCALE=CELSIUS; // Options are CELSIUS, FAHRENHEIT
IRTemp irTemp(PIN_ACQUIRE, PIN_CLOCK, PIN_DATA);
void setup(void) {
Serial.println("IRTemp example");
Serial.println("~~~~~~~~~~~~~~");
void loop(void) {
float irTemperature = irTemp.getIRTemperature(SCALE);
printTemperature("IR", irTemperature);/*issue is here - gives 'printTemperature not declared in scope'*/
float ambientTemperature = irTemp.getAmbientTemperature(SCALE);
printTemperature("Ambient", ambientTemperature);
void printTemperature(
char *type,
float temperature) {
Serial.print(type);
Serial.print(" temperature: ");
if (isnan(temperature)) {
Serial.println("Failed");
else {
Serial.print(temperature);
Serial.println(SCALE == FAHRENHEIT ? " F" : " C");
