Hello,
I have a problem with the Arduino NANO configuration and WS2812B diodes. On Arduino 1.8.19 I threw FastLED 3.5.0 and the code below. Control via the Prismatik app. Basically everything works great until I want to turn off the backlight. A dozen or so seconds after turning off the backlight, the first LED turns on by itself. It does not matter whether I turn off the backlight with the button in the program or close the entire program. Sometimes it changes its color 1-2 times a second and sometimes it stays on the first color.
What could be the reason?
#include "FastLED.h"
#define NUM_LEDS 46
#define DATA_PIN 2
// Baudrate, higher rate allows faster refresh rate and more LEDs (defined in /etc/boblight.conf)
#define serialRate 115200
// Adalight sends a "Magic Word" (defined in /etc/boblight.conf) before sending the pixel data
uint8_t prefix[] = {'A', 'd', 'a'}, hi, lo, chk, i;
// Initialise LED-array
CRGB leds[NUM_LEDS];
// Use NEOPIXEL to keep true colors
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
// Initial RGB flash
LEDS.showColor(CRGB(255, 0, 0));
LEDS.showColor(CRGB(0, 255, 0));
LEDS.showColor(CRGB(0, 0, 255));
LEDS.showColor(CRGB(0, 0, 0));
Serial.begin(serialRate);
// Send "Magic Word" string to host
Serial.print("Ada\n");
// Wait for first byte of Magic Word
for(i = 0; i < sizeof prefix; ++i) {
waitLoop: while (!Serial.available()) ;;
// Check next byte in Magic Word
if(prefix[i] == Serial.read()) continue;
// otherwise, start over
i = 0;
goto waitLoop;
// Hi, Lo, Checksum
hi=Serial.read();
lo=Serial.read();
chk=Serial.read();
// If checksum does not match go back to wait
if (chk != (hi ^ lo ^ 0x55)) {
i=0;
goto waitLoop;
memset(leds, 0, NUM_LEDS * sizeof(struct CRGB));
// Read the transmission data and set LED values
for (uint8_t i = 0; i < NUM_LEDS; i++) {
byte r, g, b;
while(!Serial.available());
r = Serial.read();
g = Serial.read();
b = Serial.read();
leds[i].r = r;
leds[i].g = g;
leds[i].b = b;
// Shows new values
FastLED.show();
