I blew up each one of mega, uno, pro micro, at the same time. I bought a pro micro as it was cheapest at local shop. I successfully used it as ISP to read signature,read and write fuses on attiny 85,m2560,m328p. But I was unable to write to flash any program. The error message as I remember(using my phone to write)-
Expected 0x14, received 0x64
For all 3 micros. My promicro is a clone loaded with leonardo bootloader. So, at is a Leonardo on breadbord.
As this is my only programmer at this moment, and a PC with parallel port for the worst case. After working this out,I will create a vtinyusb and use it for all programming .
If the issue is just how to get a ISP programmer, why not just get some of the ubiquitous, dirt cheap USBAsp ISP programmers off ebay? They're like 2-3 bucks each including shipping, and there's that GUI program you can use to easily set and read fuses/eeprom with it.
DrAzzy:
I can't. Parents won't allow me to .
The issue is how do I program using The pro micro I have on my hand.
Don't go for the signature. This happens with correct signature also.
I cant connect the pro micro and my WiFi adapter at the same time as they interfere,otherwise I had posted with the correct signature.
Do I need to change the programmer from arduino to avrisp like something ?
