Pro micro drivers
I have made a customised USB keyboard by using arduino pro micro. I have drivers installed in my computer everything works fine. But I have a question . in order to be able to use it in other computers do I need to install arduino drivers in every one of them ?
I should think that that was pretty obvious. If your "customized USB keyboard using arduino pro micro" works the PC, without the need to install drivers, you don't need to. If it doesn't, well then, you need to.
PaulS:
If your “customized USB keyboard using arduino pro micro” works the PC, without the need to install drivers, you don’t need to. If it doesn’t, well then, you need to.
I understand that. But I was eager to know as I do not have access to other computers right now. Just hooked some pushbuttons for shortcuts to frequently used characters in programming (just for fun) . Any experience ?
Thanks
I checked, it worked !
Vauxhall:
Arduinos are great for learning-by-doing :slight_smile:
Often much quicker than asking questions.
...R
